Results 1 to 5 of 5
    Question vag eeprom programmer v1.19 cable ???
    Hello all.I have a quick question in regards to vag eeprom programmer v1.19.Which cable are you guys using??Does it have to be specific??Are you using com ports or usb???And which cable would work best with this software??I have the newest version of VCDS Hexnet interface original form ross tech can I use this cable???I need to get pin for immo.
    DK Veteran andrym3's Avatar
    Vagcan+K or old vagcom
    so a old vagcom 409 kkl should work correct??
    Can anyone tell me if I need a KKL cable or if it needs to be CAN as well??
    Dec 2015
    malaga espa?a
    Kkl works perfect
