Somebody help to find the correct EEProm or ECU number for this Dodge Dart 2016 P68271035AA
Sorry very hard to read from pictures the symbols ... I don't see EEPROM here ...
Please write down what chips say ...
On the last pic there is SOIC8 something just by the edge of capacitor ... please provide better quality pics ..
S5051A is for sure not eeprom,
UTAuto (14th January, 2016)
TJA 1051 is not eeprom. S5051A is not eeprom.
Better to write down what write on ICs and not to upload blurred pictures.
First picture img 0446, what write on 8 pins IC in top left corner ?
SLE
ES16
904
No, well It might be one of those 3 IC's at the back but can't read what they are ..
Please write down, ... Maybe even if you are lucky the pads that are there are directly connected to your MCU so it will be easy to read!
155457-2 / MS84DC / 991VA V6 / MYS AK 525
155079-1 / SD80AB / 992LP V6 / MYS 99 521
By the marks this ICs are not what you looking for.
My vote is on
SLE
ES16
904
Check what pin is on GND
SLE
ES16
904
I wonder if this is it .. under some weird name
couldnt you just clear dtc codes with scanner after airbag components has been replaced?
I dont think this modules store crash data, but I might be wrong, just double check!
good luck
A simple thanks would do, If it didn't work at least I tried.
UTAuto (15th January, 2016)
hi is 25c256 the sle es16 904 read on 3v post file i will clear for u i just did one 2015 dart
