sky/sky+ box, use these tips to enter secret menu to reset/defrag
information given is to be used for educational purposes only
Don't Forget To Say Thanks If You Like My Post
IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
If It Ain't Broke Don't Fix It
baadboy (17th August, 2013), jimmynewbie (25th April, 2014), Johnain (28th May, 2013), massey10 (19th April, 2015), mentalmagpie (6th June, 2013), mickymuller (9th June, 2014), MickyT999 (23rd February, 2015), Scotlandgh22 (2nd March, 2015), vinsim (12th July, 2015), white (19th January, 2016), yawsam (13th February, 2016)
HOPES THIS HELPS
DIY SKY PLUS REPAIR
REMINDER - You are responsable for any repairs or actions taken to repair your SKY + equipment
Stage One - "Full System Reset"
1. Turn on your Sky + box
2. Press the "Services" button on your Sky+ remote
3. Select the option "System Setup"
4. Access the hidden menu by pressing "0 then 1 then select" on your Sky+ Remote
WARNING - The next Stage will result in you losing all previous recordings!!!
5. Select "Full System Reset" - (Please ignore all other options under this menu)
6. Allow the system some time to reset itself, and then it will turn off
7. Turn on the Sky Plus Box
8. Hopefully all recording problems are resolved - If not proceed to "Stage Two"
Stage Two
1. Remove Sky Plus Box "Mains Cable" - (either from wall socket or back of Sky + Box)
2. Hold down the "Left and Right Arrow Buttons" on the front of the Sky + Box
WARNING - The next stage will result in you losing all previous recordings!!!
3. Reconnect the power
4. Remain holding the "Left and Right Arrow Buttons" for around 30 seconds
5. The "Green Sky + Ring", on the front of the Sky+ Box should now light up
6. Release the "Left and Right Arrow Buttons"
7. Press Select on the front of the sky + Box
8. Now the System will "Format the Hard Drive" - The "Green Sky + Ring" will now spin backwards
9. Allow the system upto 10 minutes, and then it will turn off
10.Turn on the Sky Plus Box
11.Hopefully all recording problems are resolved - If not proceed to "Stage Three"
Stage Three
2. Hold down the "Backup Button" on the front of the Sky + Box
4. Remain holding the "Backup Button" for around 30 seconds
5. The lights on the front of the Sky+ Box should now light up
6. If your TV is connected to the Sky + Box, the following message will be displayed "Updating System Software"
7. Release the "Backup Button"
8. Allow the system upto 15 minutes, and then it will turn off
9.Turn on the Sky Plus Box
10.Hopefully all recording problems are resolved - If not you'll have to call Sky, and they'll promise to repair or replace it for ?65
SPECIAL NOTE - If the following message is displayed - "Recording Interupted" - when recording or live pause is attempted:
9 times out of 10 it means the "Sky viewing Card" IS paired with a Sky Plus Box - Just not the one your using!!!
baadboy (17th August, 2013), dragon123 (9th October, 2015), mickymuller (9th June, 2014), Nobster (16th April, 2016)
worked perfectly! cheers! no ?65 fee this time and no replacement box.... again......![]()
[QUOTE=joe516;1759]sky/sky+ box, use these tips to enter secret menu to reset/defrag[/QUOTE
i have a sky dish with no subscription, but i get all the teras tv and some other foreign channels, but my pictures on thef foreign channels seem to break up alot, whats wrong ??
hI I HAVE BEEN SEARCHING EVERY WERE FOR THIS TYPE ON INFO...
NEADLESS TO SAY MY SKYBOX HAS JUST GONE DOWN,,,AFTER I REFUSED XTRA WARRENTY FROM SKYS TELEPHONE CALL!!! HMMM SMELL A PLOT .
MANY THANKS
ARC
are you able to access more channels going into secret menu.
Does this work the same with an HD box?
ALSO
Is there another option that just resets the menu so you don't lose all your recordings? - I think I saw the engineer do this before he did a full reset before
no u didnt m8....any reset scrubs the harddrive...and it works on hd or sd plus...the holding your fingers on left and right button while powering back up is also good for getting boxes out of stuck in standby too...
As for the not losing your recordings,,the usb port on the box
was gonna be for connecting a device to capture the recordings
before doing a system reset,,or box swap,that way you could put the recordings back on box or new box and customer wouldnt lose their recordings....this is what they told us when i used to work for them 2years ago but still nothing yet...the amount of customers i got grief off was unbelievable,,yet understandable....
Anyone having problems with their remote be it sly or any other remote,,there is an easy way to check if its working....
get your mobile phone and switch the camera on...next get your
remote and put in front of camera lens,then press buttons on remote,and you can see it flashing if remote is working....
can't wait to download
sky always fool about
would be nice to fix it myself for once![]()
great info ,
i theres a guy on ebay selling all the sky engineer tips and tricks for ?2.99 , i bought it and its good but not has good has the info you can get for free from digital kaos
hahaha this made me laugh, not for the post though...i went on a bskyb installation and health and safety course recently......and one of the questions was.... wat menu is accessed by pressing services ,system setup 0 ,1 select and one numpty put the secret menu........
thats what i would put. I guess he failed?
Read the Rules here; they apply to Everyone.
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Technomate 2300 Motor
hey anybody got any info on how to fix a blurry screen on the amstrad drx 280 any help would be much appreciated cheers!
