Hi. I need to connect and turn on Opel Astra H display with CD30 radio on bench. There is standard, 32 pin plug for display. Can somebody tell me how I can do that?
Look carefully at the 32 pin socket on the display and you will see pin number refs at each end.
Use this .pdf buddy, hope it helps you............
Last edited by KierAn20; 26th January, 2016 at 06:03 PM. Reason: removed inaccurate info
clydey (25th January, 2016), Darek90 (25th January, 2016), Decode Ghost (28th January, 2016), eric paris (4th February, 2019), ilen (26th January, 2016), mijatx (22nd February, 2023), mohamad1401 (25th January, 2016), Raimax (25th January, 2016), sanixmen (25th January, 2016), shooting (25th January, 2016), stachu22 (26th January, 2016)
Thank you for solution but my display don't want start. I connected it like in solution but when I turn on 12V: display only blinks once. Radio starts good.
alessio93 (30th June, 2020), attilaa0 (13th February, 2019), cone96 (19th August, 2021), dashradio (12th February, 2019), Decode Ghost (28th January, 2016), eric paris (9th February, 2019), filan (28th January, 2016), gameiruz (4th October, 2018), Juviander (23rd April, 2023), lounadak (16th September, 2023), marmaro (18th March, 2024), mijatx (22nd February, 2023), MrRepair (2nd December, 2020), otas1 (28th January, 2016), sanchos (28th February, 2016), sanixmen (26th January, 2016), smoggy (28th January, 2016), stachu22 (28th January, 2016), timzhanghw (11th November, 2024), Zann (26th January, 2016)
Thank you! Your solution is great, display started! Can I now connect to this set my opcom or tech2 for pairing and unpairing? I found only info that in OBD2 pin 5, 4 is ground, 16 is +12V, 6 id CAN-H and 14 is CAN-L..
Ok, I found it
Pin 3 OBD for pin 22 in display plug
Pin 11 OBD for pin 23 in display plug
Working good
hello,
thanks for the pdf file
the radio come from one car and the display come from an other car
what eeprom l have to read and or virgin ?
eric paris (13th February, 2019), mijatx (22nd February, 2023), stachu22 (13th February, 2019)
You need to connect +12, GND and two wires of can between radio and display, you have pdf at KierAn20 post. Radio nad display should start. Next step is divorcing radio or/and display and pair it for the same code.
And also 24C64 in CD70 f. ex. Siemens![]()
hello
thanks for your message
l l read the eeprom and post the dump
Hi ! I conected on the bench the display of my astra H to radio and it turn on ,but can i have the pinout of the OP com ,or what pins connect to astra h display to
make pair?
I found 4,5 GND and pin 16 is 12V.
But what about CAN L and CAN H? As i understand must connect to pin 22 and pin 23 of display.
Thanks!
hello friends
wiring is good on the bench , op com see the cd30 and the gid, thanks for informations
l read the 24c32 and find the code with oscr , thanks to his creator :-)
problem when l want to désactive the radio with the code with opcom it doen't work
l think it's besause radio and gid came from two different cars
how can l désactive the radio , to re active it on an other car
eric paris (15th June, 2019), svetlim (15th June, 2019)
thanks shooting for the explication
l post the dump for the cd30 and the gid
cheiodesono (26th April, 2024)
cheiodesono (26th April, 2024), eric paris (15th June, 2019), plamenpm94 (4th December, 2020)
