Results 1 to 4 of 4
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Zgemma or E2 box Local Network (WIFI/LAN) Live Stream PC/Android/IOS guide
    This Guide will cover Streaming Live TV from your Zgemma/Enigma 2 sat box to your Local Network Wifi/Lan it will not cover streaming to the internet.
    For all Devices/OS's The Enigma2 image on your Zgemma must have the Openwebif plugin installed, openatv5.1 and openvix has this plugin installed as default.
    You will also need your Zgemma/Sat box IP address for openatv Menu-information-network and note down the IP of the box ie 134.167.1.8 yours will be different
    If your Zgemma has a single tuner the channel on your main TV will change to the stream channel, if you have a twin tuner it will use the free tuner and 2 different channels can be watched at once.
    PC Apple
    1. Download VLC player and install to applications
    http://www.videolan.org/vlc/download-macosx.en_GB.html
    2. Open safari and type in the IP address of your Zgemma this will then open your Openwebif interface
    3. Click on the TV icon see picture, the default app itunes will open and try to play the .m3u file just close itunes
    4. Drag 'stream.m3u' from download dock folder to desktop
    5. Alt click on 'stream.m3u' and select 'get info'
    6. Change 'open with to 'VLC' and click 'change all'
    7. Next time you click on the tv icon in openwebif it will auto play the stream in VLC, if you get a warning about opening the VLC app because it's been download from the internet tick box and click OK
    PC Windows I use chrome and will base the guide on this browser
    http://www.videolan.org/vlc/index.en_GB.html
    2. Download Chrome and install
    https://support.google.com/chrome/answer/95346?hl=en-GB
    3. Open Chrome and type in the IP address of your Zgemma this will then open your Openwebif interface
    4. Click on the TV icon see picture
    5. The downloaded 'stream.m3u' can then be seen in the bottom download bar, minimize chrome and go to your download folder
    6. Right click on the 'stream.m3u' file and the 'open with' and then 'choose another app' find and select VLC in the list and tick 'always use this app to open .m3u files' and click OK
    7. Maximise the Chrome screen and right click on the stream.m3u file in the bottom dowmload bar and selct 'always open files of this type'
  2. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    fatbob46 (19th April, 2020), frundlemud (1st February, 2018)
  3. #2
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Android Guide
    Android Tablet/Phone
    I found that VLC player for android buggy and wouldn't play the streams so use another app; xmtv player
    1. As xmtv player isn't available from the app store we need to 'allow installation from uknown sources' settings-security and tick 'Unknown sources'
    2. On your device download xmtv player
    http://xmtvplayer.com/download
    select Ok to keep xmtv player.apk when get 'download complete' box press open or go to your downloads and press xmtv player.apk and install and open and 'I agree' then close the app
    3. Open your device browser and type in IP address of your Zgemma, you will get the mobile version press 'show full Openwebif'
    4. Click on the TV icon see picture, you will then get a 'Complete action using' box, press xmtv player and press 'always'
    5. xmtv player will open, press your selected channel
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default IOS Ipad/Iphone Guide
    IOS Ipad/Iphone
    I found all the free apps in the app store buggy so ended up after a bit of search using Istreamgate+ it's a paid app but it's at present cheap ?1.49 I welcome any feedback on Free apps
    1. go to the app store and search 'istreamgate+' purchase and install
    2. Open the app and click on the 'folder' icon in the top right corner then click + edit the following
    IP Adress: your zgemma's IP address
    tuner: either single or multi depending on your sat box
    Press 'Save'
    3. Press the 'open book' icon in the top left corner and select your bouquet
    4. Select your channel
    IOS Ipad/Iphone (Jailbroken)
    1. Via your favourite Cydia repo or google search and download and install the .ipa for 'Blackbox Pro'
    2. The setup menu should start on first opening but if it doesn't then click 'blackbox wifi' icon top right corner ext to the spanner and click + edit the following
    Host or IP Address: your zgemma's IP address
    Label: Zgemma
    Zap mode: either single or multi depending on your sat box
    press 'Done'
    3. Press the 'folder' icon in the top left corner and press bouquets, select your bouquets
    HD Channels won't be shown, if you want HD channels then press the 'spanner' icon and 'Show HDTV channels' to ON however, they seem to lag/glitch alot
    happy_highlander's Avatar
    Aug 2010
    Quote Originally Posted by martin035 View Post
    Vu+ player is free from android play store and by far the best option for streaming any e2 box to android
