Page 5 of 10 FirstFirst 12345678910 LastLast
Results 61 to 75 of 137
  1. #61
    In a van down by the river
    can someone tell me some information about this key?
    i don't know Renault very well.
    how many different smart cards are there?
    do they work in more than one country?
    i.e. just using random countries as an example....if the renault smart card in France is not compatible with the renault smart card in Spain, etc, we need to crack both, not just one.
    if each country uses a different smart card, i need to crack them all, if we want the remote to work.
    any good info out there regarding this key and it's compatibility?
    and what is the professional reference for it - "key card", or "smart card".
    thank you
  2. #62
    as far as I am aware the difference from country to country is frequency not the contents of the chip.
    Pages 6 and 7 differ as far as virgin dump goes from car model to model.
    So for example a Megane 2 has a different virgin dump to a Laguna. But as long as we can re-write the chip, 7946 and 7947 thats no problem.
    Megane scenic clio are all interchangable as virgin cards. Laguna espace and Velsatis are all interchangable
  3. #63
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    some are hands free
  4. #64
    key card or keycard
  5. #65
    Top Poster admiralx's Avatar
    Apr 2012
    Quote Originally Posted by whiskeyman View Post
    some are hands free
    KEY CARD
  6. #66
    Quote Originally Posted by albertros View Post
    when i worked with the BMW....the software appears same for 315mhz and 868mhz...but they don't work together. i have to make two separate procedure to unlock them. i hope it is not same for renault KEY CARD hehe
  7. #67
    May 2012
    Kernel
    I dismantled two Megane MKII cards, one 315MHz and the other 432MHz. The only difference between them was the oscillator and the ceramic caps near it.
  8. The Following User Says Thank You to uberbit For This Useful Post:
    mexanico1971 (2nd August, 2019)
  9. #68
    May 2012
    Megane II/ Scenic II- 2 types:
    Normal with PCF7947
    Hands free PCF7943AT/422
    Laguna II/ Espace IV/ Vel Satis- 3 types:
    Normal 2 buttons PCF7947
    Autolock 3 buttons PCF7947
    Hands Free 3 buttons (no hole) PCF7936+ rf board.
    PCF7946 can be used instead 47
    Last edited by Listek22; 12th September, 2012 at 03:58 PM. Reason: mistake corrected.
  10. The Following User Says Thank You to Listek22 For This Useful Post:
    armpower (30th May, 2016)
  11. #69
    coolsoda's Avatar
    Apr 2008
    Scotland
    Quote Originally Posted by Listek22 View Post
    Megane II/ Scenic II- 2 types: Normal or hands free. Both with PCF7947.
    Megane Hands free does not use PCF7947
    it uses PCF7943AT/422
  12. The Following 2 Users Say Thank You to coolsoda For This Useful Post:
    mexanico1971 (2nd August, 2019), PierreTheron (13th November, 2015)
  13. #70
    May 2012
    Quote Originally Posted by coolsoda View Post
    Yes, your right. Thanks.
    Post edited.
  14. #71
    May 2012
    Quote Originally Posted by radialva View Post
    u need a virgin pcf (...)
    Precoded virgin.
  15. #72
    What tool can prepare card to program to new car without opening card? And is it possible to program used card with carprog, or card must prepared new and precoded first?
  16. #73
    May 2012
    Quote Originally Posted by athlonxp View Post
    Most important part inside of card (normal) is transponder- usually PCF7947 that can be programmed just once. So you CAN NOT PROGRAM IT MORE THAN ONCE OR/AND MAKE IT WORKS WITH OTHER CAR THAN IT WAS PROGRAMMED!! If you open "used" card, replace transponder, solder it to the board, precode it (or buy precoded), then card become "new" and can be programmed with car.
    "Used" card with fresh chip become "new".
    Is that clear?
  17. #74
    Is that clear?
    Clear. What tool can precode new chip? Zed-bull clone can? Or other tool?
  18. #75
    PierreTheron's Avatar
    Centurion,South Africa
    Zed clone can if you know how to ..
    (You will need a bit off reading here on dk and some needed transponder (Precode files)
    The problem is that with whatever reader we have we can not see alll info that can be in the chip ..
    How can i explain it???
    The manufacturer off a certain key programmer actually wants to sell us something to only do what they want us to do ..
    So they must have developed some reader that can see more than us ( Some backdoor software ) . So they give some software part we can only see on the chip and manipulate .
    All i know is that once chip locked to car some info gets hidden .
    (there must be a backdoor or software that must allow you to see what happened to that data...)
