Results 1 to 10 of 10
    Slovakia
    Default BMW N43 engine shaking on idle
    please help my with BMW 320i engine N43
    problem is a poor idle, engine litle shaking..
    faults:
    30EA DENOX CATALYTIC CONVERTER, SULPHURIZED
    30C1 Engine-oil pressure control, static
    29CE Misfire detection cylinder 2
    2A99 Crankshaft exhaust camshaft ,correlation
    I change a spark plugs, ignition coil and injector in 2. cylinder , no change
    I tested a compression at all cylinder, everything is ok
    please help me , any idea are welcome
    thank you
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by Nanu View Post
    faults:
    thank you
    What year is?
    Sent from my SM-G925F using Tapatalk
    Slovakia
    year :2009
    smokey08's Avatar
    Essex, UK
    I suspect the problem is the injector in cylinder 1. When they fail they often over fuel and then the oxygen sensor will trim fuel away from bank 1 (cylinder 1+2) making cylinder 2 lean causing it to misfire.
    What colour are the sparkplugs? 1 black and sooty? the rest look normal?
    The oil pressure code is probably a faulty solenoid in the back of the engine behind the alternator. Also check the timing chain.
    You can ignore the Nox catalyst code, 90% of the cars I code read with this engine have it stored.
  5. The Following 2 Users Say Thank You to smokey08 For This Useful Post:
    Johnner (1st February, 2016), Nanu (2nd February, 2016)
    lush29's Avatar
    Oct 2015
    year :2009
    If compression is ok, injectors coils, spark are all good. The only think is timing left
  7. The Following User Says Thank You to lush29 For This Useful Post:
  8. #6
    Slovakia
    Quote Originally Posted by smokey08 View Post
    hi, thank you for the answer
    on this car the 1 and 4 cylinder has 1 catalytic converter and the, 2 and 3 cylinder has an another cat.
    how should i check the injectors? what is the procedure? how should i test it?
    tomorow I will check the timing chain and replece it
  9. #7
    smokey08's Avatar
    Essex, UK
    Well spotted, suspect injector 3 then.
    I think there is a test to diagnose the injectors in ISTA D (there is for the N52 + N54 engines). I prefer to check sparkplugs as I find it more accurate. If there is a sparkplug wet with petrol after is has stood for a little while then injector broken. If 1 sparkplug is black sooty and the rest are ok then injector is broken.
  10. The Following User Says Thank You to smokey08 For This Useful Post:
    Nanu (3rd February, 2016)
  11. #8
    Slovakia
    hi,
    I upload pictures from spark plugs, all are black
    I replace a timing chain, this week, and I report, thanks for help
  12. #9
    remove the oil sump and check for oil strainer blockage...
  13. The Following User Says Thank You to sokisoki3 For This Useful Post:
    Nanu (4th February, 2016)
  14. #10
    Sep 2016
    Hi, I'm new to this site and came across your post and realised my car has the same issue. It is also a 320i N43 engine 2008 BMW. It shakes at idle the same way you've described your shaking, I've changed the cat converter, spark plugs, coils and the issue still persists, have you found a solution to it yet? thank you.
