Results 1 to 4 of 4
    Oct 2010
    Default ATMEL ATMEGA 32 16AU073OB
    I HAVE A valtra tractor with the above ATMEL ATMEGA 32 44pin processor , i have calculator for this mcu , i have original XPROG and Orange5 , is it safest to fully remove this processor for reading \writingproblem is that i dont have QFP adapters for either Orange5 or Xtool, i dont want to damage this processor as new dashboard is 1000 euros , any help appreciated ??
    Rerouter's Avatar
    Jul 2014
    Australia
    Provided you have something to place it on for reading, then removing will be safest, Apply some gel flux on the pins, heat with a hot air gun until you can nudge it and all pins move, then lift, '
    If you have nothing to put it on, then short the crystal pins together, They only control the peripheral pins, and will prevent it from booting before and after the programmer is used, meaning all non programming pins stay high impedance,
    The second option still has a small risk of damaging another IC that the micro is connected to on a programming pin, so your call,
    A file for feedback, This is all that is asked on this site, Did it work? what value appeared on the dash? maybe some photos or a power-up,
    Oct 2010
    Thanx for the help Rerourer , Gogalvsent me a wiring diagram , a big thanx 2 both u guys
    Oct 2010
    i need to buy a QFP Adapter for hhe above atmel 44pin surface pin poocessor, ive tried all my usual sousces bu no joy/ can anybody help me find one please
