Results 1 to 7 of 7
    bursuc's Avatar
    Oct 2011
    inside MCU
    Default Peugeot 508 - gearbox fault : P171A -brake signal fault
    Hello all dk friends,
    I have a big problem
    Car is peugeot 508 1.6 hdi with semi-auto gearbox cp300
    Engine ecu is siemens sid 807evo
    I cant erase this fault code and gearbox only drive in limp mode.
    No auto mode available
    I change. Brake pedal sensor and engine ecu ( i was thinking is the can bus in engine ecu )
    Fault :
    P171A. - brake signal fault ( switch/ can )
    On engine ecu failt codes are :
    P0685 - power relay control
    U1133. - Lin network
    U1134. -Lin network
    U1400 - Alternator Lin network
    Anyoane who had experience with this fault codes ?
    Please help.... i start dreaming this peugeot
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by bursuc View Post
    Fault :
    U1134. -Lin network
    P171a is to do with the gear swift
    Sent from my SM-G925F using Tapatalk
  3. The Following User Says Thank You to lush29 For This Useful Post:
    bursuc (10th February, 2016)
    bursuc's Avatar
    Oct 2011
    inside MCU
    Fixed. It seems there were some broken wires near alternator. Thanks
    Sent from my SM-G928F using Tapatalk
  5. The Following 2 Users Say Thank You to bursuc For This Useful Post:
    maybach_ (22nd February, 2018), Meat-Head (22nd February, 2016)
  6. #4
    I have the same fault brake like on all time . (New sensor on brake pedal) and new altinator . Same faults as title . Any ide ? Tanks for help
    bursuc's Avatar
    Oct 2011
    inside MCU
    Quote Originally Posted by citroenc4boy View Post
    Try to go with reset the auxiliary belt and make sure alternator is witg start\stop and working as original. Is same part number?
  8. #6
    reset the auxiliary belt in edc ecu ?
  9. #7
    Yes same oem number
