Results 1 to 15 of 24
    alclot's Avatar
    Melee Island
    Default MAZDA 3 2004 1.6 HDI PSA ECU + DASH FAILURE
    HELLO CAR IS MAZDA 3 2004 1.6 HDI PSA ENGINE
    + NOT STARTING
    + INMO LIGHT ON.
    + KEYS ARE OK
    + SEEMS COMM PROBLEM BETWEEN ECU AND DASHBOARD.
    ENGINE ECU PCM
    0281 011 534 4M61 - 12A650 - AC
    95160 INSIDE
    DIAG Shows errors: p1602, u0073
    DASHBOARD
    4T BN9J A 93C56 inside
    DIAG shows errors: u2516, u2510
    Have checked all wiring between, and all are ok.
    I upload dumps, I am thinking, perhaps someone can check my dumps....or even repair it.
    Any other suggest will be great, I have even disconnected almost all ecus....radio, a/c and so on....so CAN line is not disturbed, but no luck.
    THanks for help in advance
    ypiter's Avatar
    Jan 2012
    RUSSIA
    Dash bad dump
  3. The Following User Says Thank You to ypiter For This Useful Post:
    alclot (19th February, 2016)
    alclot's Avatar
    Melee Island
    Hi ypiter. Is it possible to repair the file? Thanks for responding
    ypiter's Avatar
    Jan 2012
    RUSSIA
    Hi! Need write new chip in dash dump. Then write dumps in blocks.
    Pass pm
  6. The Following User Says Thank You to ypiter For This Useful Post:
    alclot (22nd February, 2016)
    Feb 2016
    guinea conakry
    I need immo off mazda3 2004. Help please
  8. #6
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by mahmoud bourgi View Post
    Ford Mazda no way for immo off
  9. #7
    Write keys with IDS
  10. The Following User Says Thank You to xtech For This Useful Post:
  11. #8
    alclot's Avatar
    Melee Island
    Quote Originally Posted by ypiter View Post
    Pass pm
    Hi. Car no start. Give me this DTCs:
    PCM:
    P1622 IMMOBILIZER ID MISMATCH
    P1632 SMART ALTERNATOR CIRCUIT OUTPUT
    P0704 MALFUNCTION CIRCUIT BREAKER INPUT CLUTCH
    P0341 RANGE OPERATION A camshaft position
    P0562 SYSTEM UNDER STRESS
    P138B VOLTAGE GLOW PLUG CONTROL MODULE
    P0404 RANGE OF MOVEMENT CONTROL PERFORMANCE EXHAUST
    P1412 circulation valve EXHAUST FROZEN
    U0073 BUS COMMUNICATION FAILURE (CAM)
    DASH:
    B1342 THE UCE FAULT
    U0100 CAN MISS FROM PCM
    B2141 CONFIGURATION FAULT NVM
    What do you think?
    nithtmare this car ;(
    thanks in advance
  12. #9
    Jan 2011
    REUNION ISLAND
    You must take second hand dash.
    Then make module initialisation with avdi (erase ptas and learn 2 key)
    Ecu and dash will synchronised automatically.
    Envoy? de mon GT-I9515 en utilisant Tapatalk
  13. The Following User Says Thank You to WISETIGER For This Useful Post:
    alclot (25th February, 2016)
  14. #10
    alclot's Avatar
    Melee Island
    Hi Wisetiger. Only I can make this avdi procedure with car really?
    Thanks in advance
  15. #11
    Jan 2011
    REUNION ISLAND
    My friend 3 month before i had same issue with lost ecu on mazda 3
    i put used ecu and procedure worked:
    Last month I made same procedure on ford fiesta and it also worked with bosch edc16 ecu.
    Even VIN was different on dash and ECU the car was starting fine.
  16. #12
    Oct 2014
    Croatia
    did you slove problem? i have working set ecu+dash need to make new transponder
  17. #13
    alclot's Avatar
    Melee Island
    Quote Originally Posted by krpic View Post
    Hi krpic. Please send me. Thanks in advance
  18. #14
    Bulgaria
    working set dash+ECU
    B.R.
  19. The Following 9 Users Say Thank You to icogsm For This Useful Post:
    alclot (26th February, 2016), babuch93 (28th October, 2019), delta rosso (17th October, 2019), FUSED: (16th February, 2017), m35i (4th December, 2017), milanoffracing (26th July, 2016), taki183 (28th August, 2016), Toutancamon (12th September, 2020), zani70 (31st August, 2018)
  20. #15
    Oct 2014
    Croatia
    here if you did not solve
  21. The Following User Says Thank You to krpic For This Useful Post:
    alclot (7th March, 2016)
