Hi mates. I repaired some ecu?s and tested them on the car directly, work fine. But sometimes, car is far away and i get a damaged ecu shipped from a friend or a customer. Then, i have to test the ecu before reshipping.
I had MST9000, known ecu test unit from chinese sellers. I wasn?t happy with it, it didn?t work correctly for my case. So, my question, how do you test ecu on bench ?? Which tools do you recommend ?
I know, i can connect launch or DAS to read actual values and trouble codes. But i have to simulate a car on the bench. Can you help ?
THX !!!
