Results 1 to 10 of 10
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default BMW 530 E39 186PS wrong flash programming HELP!!!
    Hello Mates! I tried to reprogram DDE4 from BMW E39 3.0D using another dump. Conected MPPS and read 48kB only map area from orginal. I saved it but i forgot and write empty dump from another ecu. Empty means 512kb 'FF' and 48kb map area inside. Car don't start of cource. So I lost 512kB ori dump from that car... I write full 512kb dump from another E46 with the same software version, but car don't start. What can I do? I heve communication with ecu on bench. Is any immo data in flash memory in this case? Maybe someone could send ori with numbers as I read at the first time... Please help. i attach 1st 48KB readout, 2nd 512kb damaged dump and 3rd 512kb ori from another E46 ecu. Please help.
    Label's data:
    0 281 010 314
    7 786 581
    7787638
    MPPS data 1st ori read data:
    7789376
    1037351761
    B079EWS3040038
    3-330d SW7789376 184KM.rar
    2-readout-recovery-flash-programmer.rar
    1-7789376.rar
    Feb 2016
    I have done this before. No fix that I could fine mate.
    New ECU im afraid
    WinWoj's Avatar
    Jan 2012
    ECU City
    Mate, if you havn't Universal Flash Programmer to r/w AM29F400 you right. But If so - the way is free I think, good dump should enought..
    WinWoj's Avatar
    Jan 2012
    ECU City
    Anybody can send ori for this 530d ? Any immo data is inside flash?
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Mate... immo is in the eeprom.
    There is nothing to do with flash about immo.
    Make ECU virgine and adapt with INPA or whatever you want.
    P.S. Actually you can try first to synchronize EWS and DDE with INPA...
    Regards!
  6. The Following User Says Thank You to bobolin4o For This Useful Post:
    WinWoj (24th February, 2016)
    WinWoj's Avatar
    Jan 2012
    ECU City
    Ok. So question is why only flash change with the same SW blocking engine start... I will check attached e46 flash base (512kb) with original map area 48kb from repaired e39 and eventually dtc's on car and report.
    bobolin4o's Avatar
    This is immo 3 system... rolling code... when you play with ECU on bench... you know...
    Just try with INPA to make synchronization.
  9. The Following User Says Thank You to bobolin4o For This Useful Post:
  10. #8
    dominik.m's Avatar
    Jun 2009
    POLAND
    Your file.
    1037351761
    1037351732
    B079EWS304
    7789376
    0 281 010 314
  11. The Following User Says Thank You to dominik.m For This Useful Post:
  12. #9
    WinWoj's Avatar
    Jan 2012
    ECU City
    Oh thanks mates! I check 186ps base with ori map area and... car start. But it is 193ps and now not all working good... Maf is 170mg lower, transmission in limp, low power... So 193hp ori I need and data from label is:
    7 786 581
    7787638.
  13. #10
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by WinWoj View Post
    7 786 581
    7787638.
    Here is...try...this is soft from X5..same engine.
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  14. The Following User Says Thank You to baltazar3 For This Useful Post:
    elektrik1973 (8th January, 2019)
