Results 1 to 11 of 11
    Mar 2016
    Default Corsa D 1.3 CDTI possible turbo problem
    Hi Guys
    Hoping someone can help, The car hits about 3000 rpm and the engine management light flashes on and off quickly and the car will no longer go above 3000 rpm until i turn it off and restart.
    Just before the engine light comes on the car does pull away , but just for a second.
    I have checked the wastegate actuator and i dont see it move at all , i tuned engine off and had a friend turn it on and rev to 4000 rpm ,
    The wastegate actuator doesnt move. I tried moving it with a screwdriver with the engine off and it seems to not budge at all.
    Before stripping out the Turbo it would be great if someone could suggest anything else
    Much appreciated
    Bulld
    Aug 2011
    Spalding
    Yes you need to get it code read instead of guessing. If the light was on there should be a code.
    you need to study live data whilst it faulters.
    Live data will tell you quickly if it is overboosting.
  3. The Following User Says Thank You to MJRVR For This Useful Post:
    bulld (19th March, 2016)
    Mar 2016
    Thanks MJRVR
    Going to check with opcom today, I am not experienced in diagnosing live data , If i post the live here could you help look at it
    Thanks in advance
    racin-snake's Avatar
    Jun 2009
    Check the map sensor see if it's clogged but get codes read
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  6. The Following User Says Thank You to racin-snake For This Useful Post:
    Aug 2011
    Spalding
    Quote Originally Posted by bulld View Post
    Thanks MJRVR
    Thanks in advance
    Yes post the data.
  8. The Following User Says Thank You to MJRVR For This Useful Post:
  9. #6
    Mar 2016
    Thanks Guys , So far i got the fault code , P0234 - boost pressure high pressure.
    Going to do a live data test now
  10. #7
    Mar 2016
    Hi Guys
    here is the live data , i hit 3rd gear and immediatly the fault light flashed up , and now have overboost error again after i cleared it earlier friday2.rar
    I notice the oil pressure flicks to low at line 192 , could this be all the problem is ?
  11. #8
    Aug 2011
    Spalding
    Make sure the acuator arm isn't sticking. Or use GFF on Tis.
    (You have may have got more help if you use the thanks button now and then)
  12. The Following User Says Thank You to MJRVR For This Useful Post:
  13. #9
    Mar 2016
    Really sorry ,
    I am a newb on this , I said thanks but didnt press the button
    Again thanks , and i pressed the button
  14. #10
    Mar 2016
    Cheers MJRVR
    Corsa running perfectly now , It was a stuck actuator
    It must have been pretty bunged up inside it took a lot of force to free it up but i managed to do it without removing.
    It will probably need removal and cleaning in the future , for now its repaired
  15. #11
    busaman's Avatar
    suffolk uk
    common fault stuck actuator..
    7.31sec@203.3mph
  16. The Following User Says Thank You to busaman For This Useful Post:
    bulld (20th March, 2016)
