Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Jun 2012
    Default XProg-m V5.55 Verify Errors
    HI, i bought a Chinese clone a few weeks ago & it's worked fine until yesterday. I tried to erase/write & read a 9S12 MCU from a BMW footwell module & it looked like all was ok until it started to fail on verify. Every verify fails in different addresses, completely random. This was with the BDM board attached which i always have to use with this particular chip.
    Next i tried to do the same with a different 9S12 MCU which doesn't require the BDM adaptor & exactly the same error so it is the XProg itself that is at fault.
    Anyone have any ideas why this should suddenly happen (yes i know its cheap Chinese copy but it was working fine last time). Are there any changes i can make or is it destined for the rubbish bin ?
    Thanks in advance.
    Nogger1
    Mario3's Avatar
    Dec 2014
    version 5.5.5 is not so stable, find download 5.5.1 and downgrade it, its the most stable for clones avalible
    regards
  3. The Following User Says Thank You to Mario3 For This Useful Post:
    nogger1 (25th March, 2016)
    Jun 2012
    Quote Originally Posted by Mario3 View Post
    regards
    Thanks for the reply Mario3, i understand what you are saying about 5.5.5 but it has been stable on these particular processors from the FRM modules since i bought it a couple of months ago. It used to verify first time every time so i don't quite understand what has changed. Does the Atmega corrupt ? in which case why does it write at least 90% ok, wouldn't it be more likely to be a hardware issue ?
    Also , my XProg has a dongle, if i downgrade will i still need to use the dongle & will i lose all the 'Authorisations' that i have ?
    Nogger1
    Mario3's Avatar
    Dec 2014
    No you wont lose authorisations, and the versions with dongle are known to make problems
    Sent from my SM-N9208 using Tapatalk
    Jun 2012
    Ok but still i am wondering what changed ? it was working stable for several weeks.
    Nogger1
    Mario3's Avatar
    Dec 2014
    No. It just stops working the same with older versions 5.3 adn 5.4.5.... reflash it to 5.5.1 and it will be fine. It can be a hardware issue too but isr unlikely
    EARTH
    It is not hardware. is software. install new 555 clean xp. install c: \ program files
    I also had problems
  9. The Following User Says Thank You to datapage For This Useful Post:
    nogger1 (29th March, 2016)
  10. #8
    tehnosoftex's Avatar
    Romania
    Is definitely a software problem, something is changed it xprog box files. I have the same problem and I rewrite all the files of xprogbox software and problem is gone. After a while the problem reappear whit the same solution. I don't have it in c: \ program files , may be that's why is happening.
  11. The Following User Says Thank You to tehnosoftex For This Useful Post:
  12. #9
    May 2009
    hi
    in my case read st10f280 and veryfy errors all time whit 5.55 , i try downgrade 5.51 versi?n.
    regars
  13. #10
    Jun 2012
    Thanks to all who replied, i will do a software re-install first & report back.
    Nogger1
  14. #11
    sergei5005's Avatar
    Nov 2012
    Bs As
    Is possible use X-prog 5.55 in back version ??? Im buy clone last week,and have one problem with CD contains in package. From internet Download 5.50 versions and the software run OK and recognize device,but tried read one 95160 and the software show one banner " Need update device ". Here find download 5.55 software version and device read OK. My x-prog is without dongle.
  15. The Following User Says Thank You to sergei5005 For This Useful Post:
    rtbdiagnostic (9th March, 2020)
  16. #12
    Jun 2012
    Software re-reinstall on PC didn't work so now looking at flashing the Atmega (although i am worried aboutl osing my authorisations)
    One more question, when flashing the Atmega on the XProg box do i need to remove the chip or lift any pins ? (please say no )
  17. #13
    Jun 2012
    Quote Originally Posted by nogger1 View Post
    CORRECTION: I just did another complete software re-install & it only blinking works doesn't it.
    I uninstalled Adobe Reader, went through the registry & deleted all references to Xprog, deleted ALL files previously installed from the RAR file & i ran remove.bat from the PACTH directory. Extracted all files & foldersagain from the RAR archive into the Program Files directory & re-installed & it has read & verified every time, fantastic !!
    Thanks to all who replied with suggestions.
    Nogger1
    UPDATE: spoke tooo soon, still getting verify errors when i write a file, it seems to verify ok after an erase so looks like i will have to reflash the Atmega.
  18. #14
    Mar 2016
    I have problem with xprog sais device is silent will downgrade to 5.5.1 fix it ?
  19. #15
    Jun 2012
    check the drivers/usb port, soundslike it's not talking to the box, do any LED's come on ?
