Results 1 to 11 of 11
    siyadk's Avatar
    Dec 2012
    Default How to Program 2006 Renault Megane(II) Card key
    Hello
    This car is very few in my country, hence need assistance in programming new card (bought from dealer) via obd.
    This job doesnt pay well or worth to read UCH or BCM, hence please tell me if there is a way to program key via obd( also to pull pin via obd if required)
    PS: doesnt own CAN clip
    rob h's Avatar
    May 2011
    The fnr 4-1 tool is a good tool for this. It does not requirer a pin code.
    It is a very easy to use tool, there should be some demos on youtube.
    FNR Key Prog 4-in-1 Key Programmer for Nissan/ Ford/ Renault
  3. The Following User Says Thank You to rob h For This Useful Post:
    siyadk (3rd April, 2016)
    Faraday's Avatar
    May 2012
    The dark side of the moon
    carprog 4.74
  5. The Following User Says Thank You to Faraday For This Useful Post:
  6. #4
    lion0304's Avatar
    Oct 2014
    Both device above can programme Scenic, Megane 2 without pincode.
    But FNR 4 in 1 is my choice. 1mn job done.
  7. The Following User Says Thank You to lion0304 For This Useful Post:
  8. #5
    Faraday's Avatar
    May 2012
    carprog do it in few seconds, fnr can read pin from newer cars like traffic 2011 ( I mean clone)
  9. #6
    siyadk's Avatar
    Dec 2012
    Thanks a lot...how abt x100? Also I read somewhere about remote part won't work.
    Sent from my YOGA Tablet 2-1050L using Tapatalk
  10. #7
    Faraday's Avatar
    May 2012
    x100 very limited on Renault need pin to program card
  11. #8
    rob h's Avatar
    May 2011
    Read your bcm, and post dump in the Renault pin thread!
    http://www.digital-kaos.co.uk/forums...ht=MC9S12DG256
  12. #9
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by siyadk View Post
    Thanks a lot...how abt x100, mvp? Also I read somewhere about remote part won't work.
    MVP no problem, it bypass the pin.
  13. #10
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by p1et View Post
    MVP clone?
  14. #11
    p1et's Avatar
    Oct 2013
    I'm using original but i think M8 does this for sure also...
