Results 1 to 15 of 23
    Apr 2016
    Default DTC OFF how to do?
    Hi, i'm interesting in dtc off; I'd like to learn how to do it manually(or with winols); I know there are several software that do this job, or free service, but I want to learn. I already found dtc in some ecu like marelli, denso, siemens, but I'm not able to detect it on EDC15 or EDC16. Time ago i found a formula and an xls sheet to calc the switch of location, but i lost theme, and i don't known how to find the start of table address. Anyone can help me? anyone have a tutorial?
    Babos's Avatar
    Mar 2012
    If you can found marelli and denso and siemens you must to fast to see all dtc in edc16!
  3. The Following User Says Thank You to Babos For This Useful Post:
    GaizkaV8 (12th April, 2016)
    Apr 2016
    Quote Originally Posted by Babos View Post
    marelli and denso are enought simple. they haven't many table as edc16-17 vw(dtc P code table, manufacteur code table, class table, switch table)
    For siemens i found a very good tutorial online, it is not very difficult(ppd sid206 and sid803/a, the other never tried).
    My biggest problem is find where table start.
    Mar 2013
    do a little reserch on web.. you will find it explained
    Apr 2016
    I'm sorry, but it's a week that i'm looking and i haven't found a good tutorial or example yet.
    Babos's Avatar
    Mar 2012
    But if all can found, in world lot masters lost job
  8. The Following User Says Thank You to Babos For This Useful Post:
    CustomCars (11th April, 2016)
  9. #7
    Apr 2016
    Is not true there are also free software that to edc16 dtc off ... and free service also in this forum and other.
  10. #8
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    Quote Originally Posted by jhs101 View Post
    Only few ECU removing for free, easier ones. For hard no one has time to make it for free. And there is no software for it, even payed to provide you working solution
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  11. The Following User Says Thank You to CustomCars For This Useful Post:
    MOURAD SPCMAX (11th April, 2016)
  12. #9
    Apr 2016
    nobody lost his work for an old ecu solution...
  13. #10
    Babos's Avatar
    Mar 2012
    yes yes free only is for lucky and then when he ask again he pay
    If evry where all be free open own garage and start to do for free cars why not?
    I not see where to do for free cars
  14. The Following User Says Thank You to Babos For This Useful Post:
    mihaiservice (11th April, 2016)
  15. #11
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    So... i can teach you to switch off DTC in EDC16 ECU if you teach me to do the same in Marelli...
    Ok?
    Use Skype - is on my profile info...
    Regards!
  16. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    jhs101 (11th April, 2016), sida (12th April, 2016)
  17. #12
    Apr 2016
    I solved myself. But continue to not understand why people want to keep it so "sectret", it's an old ecu now. doesn't matter., i solved.
  18. #13
    spychu14's Avatar
    May 2011
    POLAND
    Interesting. You solved one ecu or all families EDC16 in one day ?
    VAG
  19. #14
    Apr 2016
    vag fal and psa. other not yet. is not one day.. as i say it was a week that i was looking for a solution.
  20. #15
    sasy90's Avatar
    Italy
    Hi to all , is sample on marelli and sid? Can you explain me how? Thanks
