Hello.
I have BIG problem with Fiat Doblo 1.6 MultiJet 2011 year.
Car was crashed, there was damaged front of car, ABS pump and wiring of Engine.
Car is equipped with Start & Stop system and Hill Holder system.
We can not find the same ABS pump so we bought another, from car without start & stop and hill holder systems.
Wiring from ECU was changed.
Airbag ECU reprogrammed, without errors.
In ABS i have 2 present errors:
C1213 - System configuration
U1712 - Position sensor adjustment lever.
We can not start the car. If ingnition is ON the fuel pump is working. There is no any errors in BSI and engine ECU. Light with car and padlock is not turned on.
If we try to start engine there is no reaction. Only one relay is "clicking" when we try to start engine (probably of FAN)
Relay of starter, T20 dont turn on.
Voltage on brown cable from ingnition to this relay is ok.
Cable from relay to engine ECU is OK (it is 55 pin in ECU plug).
I use for reading errors ELM327 with FiatEcuScan and Delphi. In measurment of ENGINE ECU I found info that start of car is allowed.
We add a key to immo one more time, without results.
Could somebody tell me where could be problem?
Maybe i need to turn off start & stop and Hill holder in engine ECU?
Here is dump:
MULTIJET_DOBLO_95640.rar
Numbers from ECU's cover:
0 281 017 009
51899610
263
464280SAM
E5G
On dash I have info that Hill Holder is not available, nothing more.
I will be gratefull if somebody try to help me.
