Results 1 to 15 of 20
    achaccha's Avatar
    Nov 2010
    Default SCION FR-S 2013 ALL KEY LOST
    Dear Friend
    I can say that the key is programmed into the integrated unit which is 93C86 eprom. The client lost all your keys. In some workshop they have tried to program the key using different equipment as Tcode, SKP900 and also tried reading via eprom, but all they have done is corrupt the information of the integrated unit.
    I entered with the original escanner I reset immo and after 20 minutes tells me that has zero keys, when programming does not get me any transponder. According to the catalog of JMA should the transponder is TP34, but I used this and other possibilities such as the G and H keys Toyota, also the Subaru, but no program.
    Please can you tell me what type of transponder used this vehicle?
    I would like to know if anyone has a virgin file for this integrated unit of the vehicle.
    Thank you
    ray-ray's Avatar
    I read out a Scion FR-S and a Subaru wrz (Toyota 72G) and the Subaru read out as a Mitsubishi chip.
    achaccha's Avatar
    Nov 2010
    Thank you very much for your contribution but TP34 is a 4d72 and tested this possibility without success. Perhaps the problem is the corrupt information.
    regards
    KriptoKey's Avatar
    Feb 2012
    I dont have had this car in my hands, but as I see the catalog is a 4D68. Are you have tried this possibility?
    I also understand that the key is written on the computer network (integrated unit).
    I welcome your comments
    luck
  5. The Following User Says Thank You to KriptoKey For This Useful Post:
    achaccha (17th April, 2016)
    cjawahir's Avatar
    T&T
    post dump
    cj
  7. The Following 2 Users Say Thank You to cjawahir For This Useful Post:
    achaccha (17th April, 2016), zckariya70 (17th April, 2016)
  8. #6
    achaccha's Avatar
    Nov 2010
    Thank you very much for your support.
    I await your prompt help
    a hug
  9. #7
    cjawahir's Avatar
    T&T
    need read this unit in the pic
  10. #8
    achaccha's Avatar
    Nov 2010
    Quote Originally Posted by cjawahir View Post
    Dear Friend
    I have disarmed the entire board and I have also followed the wiring according to the diagram, I found the connector "Transponder key ECU" well stapled to the body with a safety precinct. This makes me think that this vehicle is not considered the "Transponder key ECU" as part of the immobilizer.
    someone can help me with a blank file for the ecu network? (Integrated unit).
    Thank you
  11. #9
    Apr 2011
    can anyone make reset for Scion FR-S 2014 with bladed key?
    Immo box Subaru 88210CA210 with 93C86
    Thanks in advanced
    Mat
  12. #10
    Is the Immobilizer the integrated box, pm me
  13. #11
    achaccha's Avatar
    Nov 2010
    This car not have unit integrated box.
    thanks for your coment
  14. #12
    Quote Originally Posted by achaccha View Post
    have you get the car started, i mean the frs, do you still need help or you re done, which country re you from...
  15. #13
    achaccha's Avatar
    Nov 2010
    If friend thank God everything was solved. Thanks for your concern.
    https://www.youtube.com/watch?v=kWNx...ature=youtu.be
  16. #14
    siyadk's Avatar
    Dec 2012
    loved your "bingo"
    Did the tango add the transponder to dump?
  17. #15
    cjawahir's Avatar
    T&T
    so u come here ask for help , no care in the world to say thanks and u solve the car .
    care to explain ?
    cj
