Results 1 to 7 of 7
    DK Veteran elecautocr's Avatar
    Default Mini Cooper R50 tachometer display
    Hello members:
    I have a Mini Cooper 2003 R50, I replaced the "center instrument cluster" because the original was broken.
    The second-hand cluster works fine, but the LCD display on the "small tachometer" does NOT work. Tacho?s needle works, but LCD doesn?t.
    BMW part number, Hardware index, software index,bus index, can index, diagnostic index,coding index, AI level and modification index is the same on both Cluster (original and second had )
    Do you know if I need to reprogramm the second-hand cluster or other module in the car ?
    or any idea ?
    The cluster in a R50 contains the FA or ZCS which is a list of all the equipment options of the car. You need to recode the cluster to be sure that everything works properly.
  3. The Following 2 Users Say Thank You to o-dog For This Useful Post:
    elecautocr (19th April, 2016), MV auto (19th April, 2016)
    In EEP
    no need reprogram old cluster but in dtc is bad VIN I think flash fault
  5. The Following User Says Thank You to vasa For This Useful Post:
  6. #4
    If it was working before you replaced the center clock, there is definitely a mismatch. You need to recode the center instrument/clock but I would start with VASA's suggestion first. Try to manually change the VIN in that (second hand) center clock.
  7. The Following 2 Users Say Thank You to Speedosoft For This Useful Post:
  8. #5
    Quote Originally Posted by Speedosoft View Post
    It was not working before replaced the center clock, I replace "center clock" because the LCD?s in both clocks were blank.
    Manually change VIN means to read mcu processor with programmer and change in dump ??
    Is it possible to change VIN by diagnostic tool ??
  9. #6
    Just read big display with rosfar r260 or smok vin should be visible in read
  10. The Following User Says Thank You to diagtech For This Useful Post:
  11. #7
    Mar 2012
    Quote Originally Posted by elecautocr View Post
    manually change VIN could be via processor and change in dump or via diagnostic tool.
    and most probably yes you can via OBD... depend on what tool you have.
