Results 1 to 15 of 17
    Default Pop up hood activated Lexus IS 300 2014
    Hello
    I have error messege onboard - POP UP HOOD ACTIVATED
    In SRS module - clear
    Where is Pedestrian protection module in this car?
    Can someone clear after crash?
    slick_dick's Avatar
    Essex
    I also have same issue on a 15 plate is300h, srs system is clear when using techstream. Once you disconnect pop up hood errors come up in srs system. There has been talk of clearing the crash in airbag ecu, before i try would like some confirmation and this problem.
    regards
    slick
    Monday I get this car and check srs unit. If trouble codes came to SRS unit I suppose that is problem with crash.
    slick_dick's Avatar
    Essex
    i have the car here just dreading pulling it all apart, lifting cpu, fitting it only to find its the same error. hoping to start on it tomorrow once i make space for it in garage.
    will try and keep every one posted
    regards
    slick
    slick_dick's Avatar
    Essex
    Quote Originally Posted by FALCON30 View Post
    did the car come in?
    I managed to strip mine and pull off the renasas processor so far.....
    part no. 89170-53220
    regards
    slick
    No. I'm waiting. Car is in paint workshop.
    Wysłane z iPhone za pomocą Tapatalk
    slick_dick's Avatar
    Essex
    airbag ecu does hold pop up hood error
    Did you resolve problem?
    slick_dick's Avatar
    Essex
    yes
    slick_dick's Avatar
    Essex
    i have the unencrypted files for this now also!!!
    “There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
    Jan 2019
    Quote Originally Posted by slick_dick View Post
    yes
    How did you resolve this? What unit had to be replaced?
    slick_dick's Avatar
    Essex
    depends where the issue is
    post up faults!!
    and if there is no DTC thats a sign of crash ie pop up hood disabled displayed on the dash
  13. #13
    Jan 2019
    post up faults!!
    Thanks for your reply had a minor accident with a pole have replaced all parts now including 2 bonnet poppers but still getting the message POP UP HOOD ACTIVATED. No codes on techstream anymore.
  14. #14
    slick_dick's Avatar
    Essex
    crash in airbag ecu .. confirmed as per thread
  15. #15
    Jan 2019
    Thanks Is it a hard code? have to replace whole unit or can it be erased without removing unit? Thanks Again
