Page 154 of 245 FirstFirst ... 54104144149150151152153154155156157158159164204 ... LastLast
Results 2,296 to 2,310 of 3668
  1. #2296
    Tefocm's Avatar
    Sep 2013
    Planet Earth...Take me to your leader.
    Quote Originally Posted by tuning4ecu View Post
    I need coding for Octavia 2 , 1.9tdi, LHD, 280/253 mm brake disc
    1K0907379AH
    TMBHS21Z792062051
    11 3B 40 1C 09 28 00 FC 88 0B 02 E9 90 1A 00 81 28 00
    Try this, I will not guarantee anything until you upload a full autoscan. Don't forget to press thanks and reputation.
    Buy every pirate China has to offer for cheap...and WIN!
    Buy everything the original manufacturer has to SHOW YOUR SUPPORT!
  2. #2297
    Tefocm's Avatar
    Sep 2013
    Please change byte 16 to 41...
  3. The Following User Says Thank You to Tefocm For This Useful Post:
    tuning4ecu (4th February, 2020)
  4. #2298
    Tefocm's Avatar
    Sep 2013
    Guys this is what I have to put up with in order to assist you. So try to understand, the "Thanks" and "Reputation" button really makes all that much of a difference.
  5. #2299
    Feb 2020
    Glasgow
    ec1
    Quote Originally Posted by Tefocm View Post
    Welcome to DK mate, that's what we do here. All I need you to do now is to press the little star at the bottom of my post. That's to help me build my reputation.
    you sound like the man i need to speak with! perhaps you can spare me a minute or two....
    so we have a 2011 Seat Leon 1P 1.6TDI CAYC and after a long and thorough diagnosis of all components related to our initial issue, we have a suspected engine ecu failure, so we sourced and bought an ecu kit at a great price from a car the same age, model and with matching ecu numbers as a means of eliminating the old ecu, and also a means of repair (clone the ecu) in the long term should the ecu prove to be faulty, Great idea....right?!
    so i auto scanned the car with my ODIS system, saved and then we swapped it all out to carry out the related tests. lo and behold, the MK60-EC1 has decided to make our lives so much easier and wipe itself! :@ ok no problem, we have the auto scan. only problem is, it hasn't saved even though it stated it had.... so following this and pulling most of my hair out, ive been trying to work out the long coding but havent had any joy, my understanding a leon 1.6 tdi starts with 113b but beyond that i cant piece it together even with the help of calculators etc. ive attached a full auto scan extracted with a mates vag-com, i do hope someone can help build a coding file, or even point me in the direction where i can build one personally.
    vehicle spec list is as follows;
    X2B B0N D38 G0C 1AT (8G0 I THINK-DAMAGED) J2D C6A HH7 1G6 1NL 8YM 8L7 8RM 8BK 8WD 8TD 2ZQ 2B2 5SJ 5RQ QG1 7MG G39
    TPMS (Passive)
    Hill Hold
    280mm Front Discs
    253mm Rear Discs
    Start-Stop
    Please let me know if there is any more info required, i am really getting to my wits end with this car now. its been off the road leaving my mother with no transport for a month now after what appeared to be a simple siemens injector short circuit failure (common as muck)
    Many thanks in advance!
    Duncan
    Monday,03,February,2020,18:16:36:11520
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.0 (x64)
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    VIN: VSSZZZ1PZBR043163 License Plate: YX11VOP
    Mileage: 114430km-71103mi Repair Order:
    Chassis Type: 1P-SE35 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 61 62 72
    VIN: VSSZZZ1PZBR043163 Mileage: 114430km-71103miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 LG HW: 03L 906 023 KL
    Component: 1,6l R4 CR td H43 8832
    Revision: --H43--- Serial number:
    Coding: 00114016032501080000
    Shop #: WSC 99999 1023 2097151
    ASAM Dataset: EV_ECM16TDI02103L906023LG 003005
    ROD: GV_ECM16TDI021PQ36_003_SK34.rod
    VCID: 76E9C1B7C9EA3DFF8D-8022
    1 Fault Found:
    7196 - Function Restriction due to Faults in Other Modules
    U1113 00 [101] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 17
    Mileage: 114993 km
    Date: 2020.02.01
    Time: 00:17:44
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 79 °C
    Intake air temperature: 29 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 12.424 V
    Unlearning counter according OBD: 40
    Engine speed: 0 /min
    Accelerator position: normalized-Accelerator position: 0.00 %
    Battery voltage: 12.5 V
    Readiness: 0110 1000
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
    Component: ESP MK60EC1 H31 0108
    Revision: 00H31001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 04941 000 00000
    VCID: 76E9C1B7C1EA3DFF8D-8022
    4 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:18
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 20992
    Count: 195
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:13
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 20992
    Count: 279
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:13
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 20992
    Count: 295
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:13
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 20992
    Count: 270
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 5P0 907 044 P HW: 5P0 907 044 P
    Component: Climatronic H15 0702
    Revision: 00001001
    Coding: 0000000003
    ASAM Dataset: EV_Climatronic A01006
    ROD: EV_ClimaAutoBasis_SE35.rod
    VCID: 3D7B1E9BAC5CAEA78C-8068
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
    Component: BCM PQ35 M 011 0045
    Revision: BC011001
    Coding: 46180A3E8025B0C0428000809500810442019DA8425D81605C 80C7000041
    VCID: 3B7F1083BA48A097B2-806E
    Subsystem 1 - Part No: 1P0 955 119 C Labels: 1KX-955-119.CLB
    Component: Wischer 23111 22 0611
    Coding: 00DB90
    Subsystem 2 - Part No: 1P0 951 171
    Component: Innenraumuebe 010 4971
    Coding: 000000
    Subsystem 3 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
    Component: J234__A0E VW10 HI 1918
    Revision: 22014000 Serial number: 003K0PPVPC9L
    Coding: 0012357
    Shop #: WSC 06402 785 00200
    VCID: 4C9D435F2FE6172F0B-8018
    Subsystem 1 - Serial number: 6332MTS602472570
    Subsystem 2 - Serial number: 6342MTS629902520
    Subsystem 3 - Serial number: 6351HTS6PIP6H9KR
    Subsystem 4 - Serial number: 6361HTS6F5GVF6KR
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
    Component: LENKS.MODUL 009 0136
    Revision: FF010039 Serial number: 20110103100351
    Coding: 1082140002
    ASAM Dataset: EV_SMLSNGVOLWS A01004
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 79F3CA8BF8F45287E0-802C
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 1P0 959 538 C HW: 1P0 959 538 C Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAP H02 0102
    Coding: E20000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 1P0 920 910 N HW: 1P0 920 910 N
    Component: KOMBI H06 0404
    Coding: 410B00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
    ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
    VCID: 346D3BBF9F166FEF73-8060
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 D HW: 1K0 907 951
    Component: J533 Gateway H35 0614
    Revision: H35 Serial number: 241110F2002804
    Coding: 350203
    VCID: 316332AB68045AC718-8064
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H06 0404
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
    ROD: EV_Immo_UDS_VDD_RM09.rod
    VCID: 6AD1E5C78D52E91F19-803E
    1 Fault Found:
    9456681 - Key
    B104C 29 [008] - Implausible Signal
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 114435 km
    Date: 2020.02.01
    Time: 01:21:27
    Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
    Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
    Component: SG EXT.PLAYER H13 0150
    Revision: A1001003 Serial number: 7668949447
    Coding: 010000
    VCID: 2855DFCF5BDE1B0FCF-807C
    1 Fault Found:
    00457 - Central Electronics Control Module / BCM (J519)
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 36
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:02:36
    Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 1T0 959 701 AG HW: 3C0 959 793 A
    Component: TUER-SG FT 002 0312
    Revision: 12101005 Serial number: 0001565722
    Coding: 0212B0
    ASAM Dataset: EV_DCU42BroseDriveSide A03004
    ROD: EV_DCU42BroseDriveSide_VW32.rod
    VCID: 7CFDD39FF7C667AFFB-8028
    Slave Driver:
    Subsystem 1 - Part No SW: 1K0 959 704 AF HW: 1K0 959 794 S
    Component: J389__TSG-HR 006 1401
    Serial number: 00000005393226
    Coding: 000290
    1 Fault Found:
    66048 - Motor for Front Window Regulator
    B11EC 54 [009] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 251
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 65 3001
    Revision: 00H17000
    VCID: 316332ABA8045AC718-8064
    1 Fault Found:
    03803 - Steering Angle Sensor for Steering Aid
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:16:41
    Freeze Frame:
    Battery Volts: 12.4 V
    DD
    Temperature: 21.0°C
    Count: 3
    Steering Angle: 0.00°
    Count: 1
    SteerAng n.Init
    Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
    Part No SW: 1T0 959 702 AC HW: 3C0 959 792 A
    Component: TUER-SG BT 002 0312
    Revision: 14101005 Serial number: 0001641628
    Coding: 0212B0
    ASAM Dataset: EV_DCU52BrosePasseSide A03004
    ROD: EV_DCU52BrosePasseSide_SE35.rod
    Slave Passenger:
    Subsystem 1 - Part No SW: 1K0 959 703 AF HW: 1K0 959 795 S
    Component: J388__TSG-HL 006 1401
    Serial number: 00000005484282
    Coding: 000290
    Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
    Part No SW: 5P0 035 186 HW: 5P0 035 186
    Component: Media2.0 H01 0007
    Revision: 00000001 Serial number: SEZ1Z3K3994535
    Coding: 0106040004
    VCID: 6CDDE3DF8FA6F72F6B-8038
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
    Part No SW: 7N0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H35 0614
    Coding: 0303085A
    VCID: 71E3F2ABA8841AC758-8024
    Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
    Component: J367-BDM H07 0125
    Serial number: 00000000002799385413
    End-------------------------(Elapsed Time: 03:46)--------------------------
  6. #2300
    May 2018
    DUBAI UAE
    Dear all,
    I am new on site. I tried to find long coding for ESP ABS. Finally I have found this blog. Maybe some of You can help me.
    VIN: 1VWAP7A32EC010341
    US PASSAT TREND 125A6F
    Part No.: 1K0 907 379 BK
    Component: ESP MK60EC1 H31 0152
    Brake discs: 312 and 272
    I would appreciate highly Your help.
    Regards:
    Laszlo
  7. #2301
    1K0907379AH
    TMBHS21Z792062051
  8. #2302
    TOP NOTCH. I ONLY HAD TO CHANGE TO RHD
  9. The Following User Says Thank You to tuning4ecu For This Useful Post:
    Tefocm (7th February, 2020)
  10. #2303
    Oct 2013
    Any help for long coding in an Audi A3 8p 2008 abs unit 1k0614517be
    wauzzz8p39a023862 is cars vin
  11. #2304
    badziewo's Avatar
    Feb 2016
    Universe
    Hello.
    Please help to code ABS module in 2011 VW Golf 2.5
  12. #2305
    Tefocm's Avatar
    Sep 2013
    Quote Originally Posted by duncans View Post
    ec1
    TPMS (Passive)
    Hill Hold
    280mm Front Discs
    253mm Rear Discs
    Start-Stop
    Duncan
    www.Ross-Tech.com
    1 Fault Found:
    U1113 00 [101] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 17
    Mileage: 114993 km
    Date: 2020.02.01
    Time: 00:17:44
    Revision: 00H31001
    4 Faults Found:
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:18
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 20992
    Count: 195
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:13
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 20992
    Count: 279
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:13
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 20992
    Count: 295
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 251
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:13:13
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 20992
    Count: 270
    Count: 44288
    Count: 0
    Count: 0
    Count: 0
    Revision: 00001001
    Coding: 0000000003
    Revision: BC011001
    Coding: 00DB90
    Coding: 000000
    Coding: 000000
    Coding: 0012357
    Coding: 1082140002
    Coding: E20000
    Coding: 410B00
    Coding: 350203
    Serial number:
    Coding: 000000
    1 Fault Found:
    9456681 - Key
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 114435 km
    Date: 2020.02.01
    Time: 01:21:27
    Coding: 010000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 36
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:02:36
    Coding: 0212B0
    Slave Driver:
    Coding: 000290
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 251
    Revision: 00H17000
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 114435 km
    Time Indication: 0
    Date: 2014.06.24
    Time: 00:16:41
    Freeze Frame:
    DD
    Temperature: 21.0°C
    Count: 3
    Count: 1
    SteerAng n.Init
    Coding: 0212B0
    Slave Passenger:
    Coding: 000290
    Coding: 0106040004
    Coding: 0303085A
    16 3B 60 12 09 26 00 FD 68 0C 06 EA 90 1C 00 82 35 08 00
    Don't forget to press thanks and reputation, i'm from Africa boss, the laws of physics don't apply here...Shake, Blow and Throw some bones and lightning is sent quicker than FedEX...
  13. #2306
    Tefocm's Avatar
    Sep 2013
    Quote Originally Posted by multi666 View Post
    TIGRI007 was not talking smack...Please upload a full autoscan mate.
  14. #2307
    Tefocm's Avatar
    Sep 2013
    Quote Originally Posted by badziewo View Post
    Hello.
    11 4B 40 0C 49 27 00 01 88 12 02 EA 92 20 00 42 B7 00 00
    There you go mate...You know what you have to do...
  15. The Following User Says Thank You to Tefocm For This Useful Post:
    badziewo (6th February, 2020)
  16. #2308
    Tefocm's Avatar
    Sep 2013
    13 62 60 1A 09 24 00 FD C8 13 04 EA 90 1B 00 81 38 00 00
    You really are a hard nut to crack mate. Did a google search of your VIN, found out you have been having this problem for a while. You asked for help on every possible forum, and everytime you failed to produce an autoscan.
    What the autoscan does is that it helps us with information regarding your car. All features and all. Give that a try. Don't forget to press Thanks and Rep.
  17. The Following User Says Thank You to Tefocm For This Useful Post:
    multi666 (6th February, 2020)
  18. #2309
    Tefocm's Avatar
    Sep 2013
    Quote Originally Posted by lapolgar View Post
    Dear all,
    Regards:
    Laszlo
    Hi Laszlo, please upload a full autoscan of your vehicle so I can assist.
  19. #2310
    Oct 2013
    my vcds not aply to do it i am do it tommorow morning with the new one
