thanks vagva,you have thanks in advance but not work,coding not accepted,where is a problem,please more try
I'm counted the characters ,missing 2 zero,coding corect ,thanks again vagva,problem solved
11424012092800FB881402EC901A00423800
11424012092800FB881402EC901A0042380000
but any ideea how solved this
Thursday,03,January,2019,16:10:44:62939
VCDS Version: Release 12.12.0
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Control Module Part Number: 8P0 920 932 N HW: 8P0 920 932 N
Component and/or Version: KOMBIINSTR. VDO H04 0150
Software Coding: 0260028
Work Shop Code: WSC 65536 645 577705
VCID: 3F8DA5776E8867E6AD9-806A
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 181912 km
Time Indication: 0
Date: 2002.05.26
Time: 03:19:06
don-t work button start -stop
in abs don-t have error,only in instrument cluster
It has not worked for me I attached the log thank you very much
Monday,09,December,2019,20:04:25:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WVWZZZ13ZAV410646 License Plate:
Mileage: 235670km-146438mi Repair Order:
Chassis Type: 13-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 3C 3D 42 44 46 47 52 55 5C 5F
B9
VIN: WVWZZZ13ZAV410646 Mileage: 235670km-146438miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Not registered 0001
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
3D-Special Function -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Malfunction 0010
B9-Aux. Display -- Status: OK 0000
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 R HW: 03L 906 022 G
Component: R4 2,0L EDC G000SG 3887
Revision: 13H02--- Serial number:
Coding: 0000072
Shop #: WSC 01000 002 1048576
VCID: 3467AAD1573B68EA01-8060
2 Faults Found:
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 8
Reset counter: 255
Mileage: 235347 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 21.6°C
Voltage: 11.93 V
Bin. Bits: 00000000
Torque: 219.0 Nm
Temperature: 18.0°C
049508 - No Communications with HVAC Control Module (J301)
U0164 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 255
Mileage: 235347 km
Time Indication: 0
Date: 2019.11.30
Time: 22:13:07
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Temperature: 21.6°C
Voltage: 11.86 V
Bin. Bits: 00000000
Torque: 219.0 Nm
Temperature: 18.0°C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 00020 790 00000
VCID: 75E157D5DCC131E2F6-8020
2 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Time Indication: 0
Date: 2019.12.09
Time: 19:59:30
Freeze Frame:
Count: 7
Count: 2
Count: 4096
Count: 195
Count: 43008
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Time Indication: 0
Date: 2019.12.09
Time: 19:59:30
Freeze Frame:
Count: 2
Count: 2
Count: 0
Count: 295
Count: 43264
Count: 0
Count: 254
Count: 0
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5ND 907 044 E HW: 5ND 907 044 E
Component: Climatronic H03 0404
Revision: 00001K02
Coding: 0018000002
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 4487FA11CF9BD86AB1-8010
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AB HW: 5K0 937 087 AB
Component: BCM PQ35 H 122 0174
Revision: BE122001
Coding: 46180A388827E30060080040340008EC4BF5000863208560E4 8060040000
Subsystem 1 - Part No: 1K8 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 28050 22 0602
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 060709 05 54 0402
Coding: 0330ED
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Coding: 000000
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Time Indication: 0
Date: 2019.12.09
Time: 19:59:34
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 K HW: 1K0 919 475 K
Component: PARKHILFE 005 1706
Revision: 00005000 Serial number: 0 263 004 388
Coding: 300001
VCID: 3A7B84E9B55F9E9ADB-806E
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0G AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D01C2CE
Coding: 0012359
VCID: 6FED65BD7E9D0B323C-803A
Subsystem 1 - Serial number: 6332MSME48521A09A
Subsystem 2 - Serial number: 6342MSME485171648
Subsystem 3 - Serial number: 6352QSME53304F3CM
Subsystem 4 - Serial number: 6362QSME53304110
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 055 0111
Coding: 0000001
VCID: 78FF5EE10BD34C8AED-802C
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1K8 920 885 H HW: 1K8 920 885 H
Component: KOMBI H04 1018
Serial number: 00000000000000
Coding: 070F010000
Shop #: WSC 00020 999 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3C7782F1B76BA0AAC9-8068
1 Fault Found:
13648640 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Date: 2019.12.09
Time: 19:59:30
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1663
Revision: H51 Serial number: 11111300F12077
Coding: 354000
Shop #: WSC 19460 666 12345
VCID: 72EB6CC9ADAF26DAD3-8026
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 235673 km
Time Indication: 0
Date: 2019.12.09
Time: 19:59:31
02797 - Control Module for Directional Stabilization Assistance (J759)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Time Indication: 0
Date: 2019.12.09
Time: 19:59:31
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 1018
Serial number:
Coding: 000000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB74A98D7FEE1A6B-803E
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 A
Component: HRE_Master H11 0071
Serial number: 0346440820
Coding: 01031102
Shop #: WSC 00028 028 00067
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW32.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 A
Component: HRE_Slave H11 0071
Serial number: 0345095797
Coding: 010311
Address 3D: Special Function Labels: None
Part No SW: 1F9 909 919 A HW: 1F9 909 919 A
Component: MultifunctionDevice
Revision: ÿ
Coding: 11003F
Shop #: WSC 67071 123 12351
VCID: 366390D941477AFA3F-8062
Subsystem 1 - Part No: 6C0 959 442 C
Component: E221__MFL-DC1
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2115
Coding: 0022647
VCID: 39799BE570599582D2-806C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H17000
VCID: 2F6DA5BDBE1D4B327C-807A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Time Indication: 0
Date: 2019.12.09
Time: 19:59:29
Freeze Frame:
Voltage: 12.13 V
DD
Temperature: 32.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000062
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 285F4EA153F31C0ABD-807C
5 Faults Found:
9462035 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 243
9636883 - Loudspeaker 1 in Double-Subwoofer
B130C 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 243
9637139 - Loudspeaker 2 in Double-Subwoofer
B130D 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 10
9637138 - Loudspeaker 2 in Double-Subwoofer
B130D 12 [008] - Short to Plus
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 9
Mileage: 235148 km
Date: 2019.11.26
Time: 22:41:32
9637137 - Loudspeaker 2 in Double-Subwoofer
B130D 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 5
Fault Frequency: 48
Reset counter: 248
Mileage: 235175 km
Date: 2019.11.27
Time: 22:06:27
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0020854
VCID: 3A7B84E9755F9E9ADB-806E
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 068200000B000000
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 377D9DDD8E4D83F224-8062
Left_headlamp_power_output_stage:
Subsystem 1 - Part No: 3D0 941 329 E Labels: 3D0-941-329.CLB
Right_headlamp_power_output_stage:
Subsystem 2 - Part No: 3D0 941 329 E Labels: 3D0-941-329.CLB
5 Faults Found:
13636608 - Control Module Incorrectly Coded
U1014 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Date: 2019.12.09
Time: 19:59:30
5276145 - Power Output Module for Left Headlamp
C1081 F1 [137] - Incorrectly Coded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Date: 2019.12.09
Time: 19:59:30
5276401 - Power Output Module for Right Headlamp
C1082 F1 [137] - Incorrectly Coded
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Date: 2019.12.09
Time: 19:59:30
5256213 - Front Left Ride-Height Sensor
C1034 15 [137] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Date: 2019.12.09
Time: 19:59:30
13705475 - Databus
U1121 00 [137] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Date: 2019.12.09
Time: 19:59:30
Address 5C: Lane Maintain.
Cannot be reached
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 D HW: 5K7 035 200 D
Component: MU-S--ER H22 0245
Serial number: VWZAZ2R8958080
Coding: 02130600FF00000011110005000808001F0107D40020010003
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 2541479524E1016286-8070
1 Fault Found:
6714 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 248
Mileage: 235673 km
Date: 2019.12.09
Time: 19:59:34
Voltage terminal 30: 11.6 V
Network diagnosis-Status: Enabled
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 1K8 919 527 B HW: 1K8 919 527 B
Component: ZUSATZANZEIGE H08 0003
Coding: 05
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
End-------------------------(Elapsed Time: 02:58)--------------------------
Hi, I will be grateful if anyone could calculate coding for me:
Audi A3, 1.9 TDI, 2009, 77kW, BLS
VIN: WAUZZZ8P09A071612
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Shop #: WSC 47635 001 104857
VCID: 7EF33C50E936D6BFEB-802A
pipina (6th January, 2020)
Please i need long coding abs jetta 2.5 usa 1k00907379bc VIN 3VWDZ7AJ0BM332640
please long coding ESP MK60EC1 1K0 907 379AD
VIN TMBHS21Z882210335 Škoda Octavia combi 2008 1,9TDI BLS
Hi, can you help me?
I need a long coding for my abs
VIN: 3vwln6168bm066250
1K0 907 379 BJ
Jetta MK6 2011 TSI
HLAVICKA11 (7th January, 2020)
zcataide (7th January, 2020)
Hi, i need a long coding for abs 1k0907379bc
vin 3VWDP7AJ2DM373876
Hi VAG, i can´t program with this codes. The ABS System generate this error: "Coding Reject: ERROR 12: Sub-function not supported or invalid format".
Follow the advanced ID:
Tuesday,07,January,2020,10:25:03:00007
VCDS Version: Release 18.9.0 (x64)
Software Coding:
Work Shop Code:
VCID: 55A13755BC0151E2D6-8000
Advanced Identification
Identification: TT1-000
Revision: 00H31001
Date: 19.12.10
Manufacturer number: 0104
Test stand number: 0601
Flash Status
Programming Attempts(application): 1
Successful Attempts(application): 1
Programming Status: 00000000
Flash Date: 2000.00.00
Flash Tool Code: 36705 933 20200
VCDS Info:
VCID: 7BF541EDEAE5679280-802E
Labels: 1K0-907-379-60EC1F.clb
Software Coding:
Work Shop Code:
Revision: 00H31001
Date: 19.12.10
Flash Status
VCDS Info:
... because the codes aren't correct
* MK100;
ketchups (8th January, 2020)
