Results 1 to 7 of 7
    pataroucci's Avatar
    Jan 2014
    Default Renault CAN CLIP 157 FULL Version Torrent
    Hi everybody
    Renault CAN Clip V 157
    Year / Release Date: 2016
    Version: 157
    Requirements: X86
    Language: Multilingual (Russian present in)
    Description: Renault car program for the diagnosis of electronic systems, Dacia and Samsung.
    Extras. Information: to upgrade, and with zero. Before installing from scratch apply Crack Renault CLIP.reg Activation files (Patch V3).
    Choice of 2 tablets: V3 Patch and keygen.
    Installing the patch in a text README file! .txt In the activation file (Patch V3).
    Press the button if my post Was helpful
  2. The Following 3 Users Say Thank You to pataroucci For This Useful Post:
    seval (28th November, 2021), ssdias (29th July, 2017)
  3. #2
    Dufner
    Johnner's Avatar
    Éire
    No torrents mate,please !!
    Jun 2015
    United Kingdom
  5. The Following 7 Users Say Thank You to janake For This Useful Post:
    alle bmw (19th May, 2016), dupisa (13th June, 2016), electricarsur (2nd June, 2016), gadget78 (10th June, 2016), otas1 (5th September, 2016), toalecs (3rd September, 2016), vasa (28th October, 2016)
  6. #4
    works very well, including the key gen, only way i could get it working on one lappy
    as the RSRWin didnt work, but on the other lappy it did !? not sure why, both on winxp etc etc ..
    anyhows got it working Thankyou @janake
    on a diff subject, do you now how to get Clip to use unregistered bluetooth drivers
    (from what i have read only the panasonic/Toshiba bluetooth/drivers are registered/allowed to work ...)
    did read pairing VI with pin of JCIPROBE works, but that hasnt worked, as thats not the pin !
    well after some research, it looks like it only works on the toshiba bluetooth stack....
    so now going to try install that, of which you need modified stack to work on non toshiba hardware etc ...
    if not will get a toshiba branded bluetooth dongle (couple pounds or so on the bay)
    but i cannot find anyone else whos done this !? ...
    EDIT EDIT EDIT ....
    Ok this works ! getting the Toshiba BT stack, mod it to work with ANY bluetooth brand
    and boom, clip works wirelessly (no need to pair, Clip sorts all that out!)
    following this Tuturial helps alot ... http://www.wiinupro.com/tutorials/toshiba-stack
  8. #6
    Feb 2013
    Egypt
    any one tell me how i can solve this problem
    need validit how i can make that
  9. #7
    at the risk of being thick have you pushed the (car and spyglass) button on the top row?
    Looks like you are searching the Manual.
