Results 1 to 15 of 28
    marek128's Avatar
    Jun 2012
    Default BMW BM54 MP3 SUPPORT ID3TAG MOD AUX IN MOD
    Hey.
    IM looking for complete set of lastest software for BM54 BMW tuner:
    29F400BT 24C64 AT27LV010A
    Lastest Software is most powerful. In attachment i send u AUX IN MOD - some units dont hawe posibility to turn on aux so need reflash all those chips my dumps.
    Also i attached a 29F400 mp3 frimware but on my unit dont worked becuse i think need update 24c64 and AT27LV010A too, or need MKIV NAVI unit. I hawe MKIII only but i ment to work with....
    Guys we need to work it out, this who hawe E39 E46 E53 E38 we can do great job. Next functionally will be ob board PC names CarX.
    Waiting for u reply......
    Best regards...
    If I help You. please say THANKS.
  2. The Following 4 Users Say Thank You to marek128 For This Useful Post:
    audiopoint (11th May, 2016), TERNOCOD (11th May, 2016), Tomate (8th April, 2018), zabra (11th May, 2016)
  3. #2
    marek128's Avatar
    Jun 2012
    Rest of files ->
  4. The Following 4 Users Say Thank You to marek128 For This Useful Post:
    audiopoint (11th May, 2016), Eddy40 (16th December, 2018), TERNOCOD (11th May, 2016), zabra (11th May, 2016)
  5. #3
    gapco's Avatar
    Jan 2012
    Johannesburg,South Africa
    What model is your tuner/amplifier. BE6525 or BE6526 ? What is the software version of your unit ?
    What will you connect to pin #4 ?
  6. #4
    marek128's Avatar
    Jun 2012
    I put back this crap to car becuse no sound when im driving.... i thint saturday round 2!
    Why u askin of model? BM54 is not enought? I hawe unit witn flat pins.
    I hawe no opition in NCS/INPA coding for AUX. Sumary it is but after invidual coding and read again its same:
    AUX input:
    keine_AUX
    gapco's Avatar
    Jan 2012
    Quote Originally Posted by marek128 View Post
    AUX input:
    keine_AUX
    BM54 is not a model it is the series. There are six different variants in the BM54 series. I need the model AND software version to see if you can program what you want.
    And you have not said what you are connecting to pin #4.
    If you want help give me the answers.
  8. #6
    marek128's Avatar
    Jun 2012
    Here u go from - INPA IDENT.
    Cant pull from car till saturday.
    In live data i see to detect aux adapter, so when i make this adapter aux will active by self?
    Found label with same part number. 6526?
    Software number from inpa says seems to 60.
    So with this adapter aux will be recognised?
  9. The Following User Says Thank You to marek128 For This Useful Post:
    TERNOCOD (13th May, 2016)
  10. #7
    gapco's Avatar
    Jan 2012
    Software version EC 103 is the correct one. With your AUX adapter the tuner/amp BE 6526 should work automatically.There is no need to flash any components. You should experiment with another tuner/amp that has the same software version.
  11. The Following User Says Thank You to gapco For This Useful Post:
    marek128 (13th May, 2016)
  12. #8
    marek128's Avatar
    Jun 2012
    Bro i need mp3 support and id3 tag. I reflash 29F400 by that dump ive posted but tuner not UP. Second question why i cant recode by NCS opition AUX_input ???
  13. #9
    gapco's Avatar
    Jan 2012
    What is NCS option ?
    Are you flashing the tuner in the car or on the bench (table) ?
  14. #10
    marek128's Avatar
    Jun 2012
    U cant flash it in car becuse gt1 ISTA P or WinKFP has no flash files for it and no opition.
  15. #11
    gapco's Avatar
    Jan 2012
    OK so you want to flash the tuner on the bench.
    On the red 10 pin MicroMatch connector WHAT ARE GOING TO CONNECT TO PIN # 4 ???????
    Answer that and maybe I can help you.
  16. #12
    Becker BM54 65126976963_652656497866_KW35.rar
    This is full software set! You need to reprogram 27lv010A to a new generation. You have old generation radio module.
    Check for 4558 for AUX on vertical PCB
  17. #13
    Sep 2016
    Hi!
    I have bought a failed bm54... the 29f400 is missing on the pcb!
    This are the information on the sticker on the bm54.
    BMW PROFESSIONAL BM 54
    65.12-6 922 510 AI:02
    BE 652626016148 EC:151
    INDEX:E 7E84.P KW:40/02
    Has someone flashfiles?!
    Thanks!
    Gesendet von meinem SM-G930F mit Tapatalk
  18. #14
    Sep 2016
    On the pcb stand 6523
  19. #15
    Sep 2016
    Where can i find flashit9 cracked and working?
