Hi i heve a rb4 dash from a audi a 4 and i repair for a sensor, put i car and inmo light on.
can someone repair the dump?24c08.rar
I don't understand your issue...
gpmoto2 (11th May, 2016)
I open the dash to repair oil level sensor error, I repair this fault and when I put in car the inmo light it's blinking and not start the car.
I put inmo number with vag das can and the car start but I have vin fault in airbag, I read dump after an not have vin....
VIN has nothing todo w/ immobilizer nor the possibility to start the car.
Nevertheless, your VIN is stored properly in eeprom dump: WAUZZZ8E53A182775
Basically you should stop working w/ VAGdashCAN immediately. Otherwise your cluster will get broken.
Meat-Head (12th May, 2016)
Bosch RB4/RB8 is displaying oil notifications in dis. So no possiblity to remove led from pcb.
i have error on dis oil sensor fault and i repair, with the dump on first post the car not start.
i modify with vagdasca and the car start but eeror in airbag and i have this dump
24c08 leida.rar
if i copy vin to dis file it?s enought?
like this:
24c08 leida mod.rar
Write VIN manuall to your working dump and problem is solved.
with tha las dump the car still start, now wait to abs fault
There are several tools which are suggested by DK:
AVDI, Smok, Cee, Dejavu ...
vag eeprom programmer 1.19 also works very well with these dash and is free. i swapped +-10 of these dash without any problems
