Results 1 to 8 of 8
    Default VITO W639 CHECK DUMP PLEASE
    Hello!!!
    I am checking this Ezs rigth now.
    Keys are ok itself.
    Coils ( Ezs and Key ones are ok also)
    Both keys are good way, almost new...
    But they stopped working suddenly ....
    Ive resolder and no luck.
    I need to check my flash dump to check CORRUPTION
    IVE upload also Eeprom, perhaps Keys are hashed ( I dont think so)
    If finally my data are OK, they are all readen with R270 Blue Rosfar.
    Take it as there are no one with this Ref in Forum in Rosfar format.
    Perhaps could help someone in the future.
    A6395450908
    3300.2307
    433.92MHZ
    ZGS001
    8504
    1011505261706190 H1
    0L01Y
    Thanks beforehand
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Flash will not corrupt by itself (or maybe a bad battery). Eeprom looks good (no error, 2 keys active).
    Did you check ESL? Common problems on Vito/Sprinter.
  3. The Following 5 Users Say Thank You to lupu_sandu For This Useful Post:
    BusCan (16th April, 2024), daxxer (16th May, 2016), GolfmkI (17th May, 2016), pike (16th May, 2016), wixu (11th January, 2019)
    Shmortz's Avatar
    in the middle of nowhere
    you can try emulate esl and see if ezs working
  5. The Following 2 Users Say Thank You to Shmortz For This Useful Post:
  6. #4
    Of course I am emulating Esl
    Because I am working in Bench
    In fact the first thing ive checked is Esl, very common on Vito and Sprinter.
    As I said I test tipycal coil key failure and also check coil inside Ezs.
    IN fact last month Ive repair one of them with 1 coil circuit Open.
    But now I dont KNow what is happening.
    At least at this moment I can Know (thanks to you) that keys are not disabled and eeprom seems correct.
    I am checking again whole Ezs.
    I need to find where is the problem.
    Any help will be appreciated, thanks beforehand.
    Mario3's Avatar
    Dec 2014
    I had a similar problem on a w639 but with 2x908. It was a fault on the pcb itself and i never found it.. swapped mcus to another eis and all was fine.
    Problem was no 15R and no start, key opened esl and everything else was fine.
    So try to find same eis and clone eeprom
    Sent from my SM-N9208 using Tapatalk
  8. #6
    workshop
    must copper contact clear,allways on w639
  9. #7
    Mario3's Avatar
    Dec 2014
    Quote Originally Posted by mercis View Post
    Wich contact exactly you mean ?
  10. #8
    Sep 2012
    Default ezs a6395450908 vito mercedes 2009
    good evening. I was looking for flash for ezs A6395450908 for vito year 2009. I think my flash is corrupt. If someone can help me please.
