Results 1 to 15 of 18
    UK
    Default Mercedes Slk R171 cluster not working
    Hi all
    Bit of an odd one..
    2006 Slk was resprayed then put into an oven to dry overnight at 50c. In morning when ignition was turned on, the dash all lit up red then died. Now airbag & abs light is permanently on even when key is out of ignition. Nothing else on the cluster works, roof also stopped working. Star cannot communicate with IC. There is 12v going to cluster plug so I would say that cluster is at fault. Does anyone know what component(s) needs to be replaced when cluster goes like this pls.
    if this post was usefull
    please press
    the thanks button
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Wow car got cooked well done .. Benz don't like to be well done.
    clusters's Avatar
    Mar 2015
    Canada
    Not odd at all, happens all the time.
    UK
    Quote Originally Posted by clusters View Post
    Do you know which component needs to be changed pls? Can cluster be repaired?
    please press
    the thanks button
    UK
    Anyone have any ideas pls?
    please press
    the thanks button
    volismb's Avatar
    Feb 2016
    Quote Originally Posted by looly View Post
    It is difficult to answer your question. Have you checked with DAS or Xentry to see what fault codes you have in the car? If cluster is dead you will see "Lost communication with ICM". Start by reading the fault codes and then post results here.
    UK
    Quote Originally Posted by volismb View Post
    Star cannot get comms with IC (I did say this in original post) so I suspect that the cluster is dead. Does anyone know which component is likely to be faulty ?
    please press
    the thanks button
    volismb's Avatar
    Feb 2016
    Any faults in the other units, like EIS, ECM, SRS and so on?
    If the lights in the cluster are working this means it is not completely dead, maybe just its CAN communication. Can you try to connect the cluster on bench?
  9. The Following User Says Thank You to volismb For This Useful Post:
    looly (23rd May, 2016)
  10. #9
    UK
    No other faults in system. Powered dash up on bench 12v- pin1 and 12v+ pin 4 and only the srs and abs lights light up, nothing else at all.
    If a replacement cluster is required then which numbers must match? Only the Mercedes A........ number or others too?
    please press
    the thanks button
  11. #10
    volismb's Avatar
    Feb 2016
    Check in EPC which part numbers are compatible with the part number of your dash.
    Our of curiosity - can you post the eeprom dump of the dead dash?
  12. #11
    UK
    Yes I will read the eeprom tomorrow and post here. IIRC it's a 24c16 in that dash?
    please press
    the thanks button
  13. #12
    UK
    Here is 24c16 dump from the dash.
    please press
    the thanks button
  14. #13
    volismb's Avatar
    Feb 2016
    The eeprom looks normal, try putting this eeprom in your donor dash and hopefully it will work fine
  15. The Following 2 Users Say Thank You to volismb For This Useful Post:
    looly (24th May, 2016), MV auto (24th May, 2016)
  16. #14
    UK
    Will do, thanks for your help
    please press
    the thanks button
  17. #15
    DK Veteran dollarbill's Avatar
    france,paris
    Are you try another key ? Sometimes if the key is wrong the vehicle start but nothing work
    if i help don't forget a thanks
