Hello friends, I need to add a key or reset Smart Key and ID box modules. Or any body clear a dude on the proccedure. A have a virgin remote Tiris TMS37200. Need to virginize modules?. Thanks in advance.
Hello M8,
Please check your Smart key dump very well you should have S93C86 have already virginilized your ECU ID CODE for you.
luis12 (7th June, 2016)
I will send you pic of Smart ECU photo, thanks friend.
Will prepare you a virgin file tomorrow
Hello M8,
Write this dump and report... both are virgin PASS in PM
Always show appreciation to ur helper NO + THANKS = NO HELP
Dumps writed, now TIS says need to turn swich ign on with registered key for register new key, I dont know why if modules are virgin it says registered key and how to turn on ign, thanks friends.
Hold on friend let me check the dump on your smart key, will get back to you soon
Hello M8,
Write this dump to your smart key, same pass as before.
Friend its not posible to write 2K in a 96C66A eprom, I think your assuming is a 93C86.
hi,
did you solve the problem with reset dump in smart module?
b.r
No friend still have issue, still two keys registered, Dash turns on but no unlocks Steering lock.
Hello M8,
Try and follow this steps to start the engine perform syncronize between the ECU and IMMO open driver's door, turn ignition ON short terminals Tc (PIN13) CG(PIN5)in the DLC/OBDII connector leave it for 45minutes the car should start.
u need to sync steering lock with id code, use x100, skp900 or TIS for this or post steering lock dump 93lc46 i will virginize it![]()
No Thanks, No Report = No HELP
Thanks friend let me try...
