Results 1 to 15 of 16
    Default mitsubishi Space star 2002 immo.
    Hi guys I'm trying to help a friend of mine out he has lost the keys for his 2002 Mitsubishi Space Star. I have cut a key for him and have got some ID 44 CRYPTO PCF7935 Transponders but I have had trouble coding the key. I have tried with MPV , x100 pro loads up asks for pin which is prefilled click program key and nothing(But they don't list Europe version). Also tried with EFFI I read the Immo dump (93C56x16) with UPA loaded it to Tm100 and it says Unknown Version. I loaded it to EFFI and it displayed the correct module. So I proceeded to write the transponder which wrote successfully. Went back to the car still not starting. Can anyone check my dump with AVDI,Tango ect?mitsu 16.rarmitsu 16.rar But soon after this my zedbull starting flick and saying contact dealer so not sure if it wrote correct.
    Cheers all
    p1et's Avatar
    Oct 2013
    Tango does not recognise the file.
  3. The Following User Says Thank You to p1et For This Useful Post:
    Galee (4th June, 2016)
    I shall reread
    Hello mate,
    I heave loaded your dump in Tmpro2 and is recognized.However i had the same problem sometimes ago on a Mitsubishi carisma and finally started it using the SBB and a Blank PCF7935 precoded into Mitsubishi 44 by EFFi.
    Best Regards, Serge
  6. The Following User Says Thank You to ngakson2002 For This Useful Post:
    Galee (5th June, 2016)
    p1et's Avatar
    Oct 2013
    Yes, I also confirm SBB works good good with Carisma.
  8. The Following User Says Thank You to p1et For This Useful Post:
  9. #6
    Yes guys have reread with VVDI prog usb upa xprog all the same dump. I did not try sbb but have it here so shall try that precode with effi then program with sbb. I'll let you know
  10. #7
    Okay loaded dump to effi wrote chip went to car today install immo plug in sbb select Mitsubishi space star loads up asks for prefilled pin code I click program key it waits a few secs then says Ecu disconnect. Any ideas guys?
  11. #8
    Quote Originally Posted by Galee View Post
    Hello Mate,
    SBB is very sensitive with respect to battery output Voltage.Check that the car battery is completely charged and repeat the procedure following disconnection and reconnection of the SBB.If the same error is experienced, then your SBB can't do the work (poor clone quality) also try the following if may help:
    >>> Disconnect the SBB from the DLC,
    >>> try to start car and let key spring back. DO NOT turn key off.
    >>> Let sit for a minute, and then plug SDD back in and restart the process
    Good Luck
  12. #9
    Thanks mate shall give it a try the battery was a little low so maybe that's it.
  13. #10
    tmkz's Avatar
    Sep 2010
    PL
    i the same problem today, Carisma, red immobox bosch...
  14. #11
    Jul 2015
    Quote Originally Posted by tmkz View Post
    Precode your blank 7935 with your EFFI use your SBB to program via obd2 simple as ABC.
    Always show appreciation to ur helper NO + THANKS = NO HELP
  15. #12
    Mate Ive done that precoded transponder with my dump with effi then to car plug in immo box still not start plug in sbb go to program key then get error. I try with mpv the same go through the menus shows no programmed keys. Go to program key and waits for min then says error. Sbb again goes to program key then get error. X100 pro goes to program key then it just goes to the program key screen again. Can none of these tools do this car? Anyone with tmpro that could make a transponder for me at all? I have some beer tokens here waiting for any kind member
  16. #13
    Jul 2015
    Hello M8,
    Please confirm if the battery is normal 10.58 or more through your sbb, did you use blank 7935? if that is correct on ignition for an hour and retry to program with sbb. If it doesnt work then use your AVDI +TAGProgrammer to precode blank pcf7935AS
  17. #14
    Hi yes had jumper leads connected with car running (not for a hour) yes use blank pcf7935 loaded dump to effi wrote transponder okay but not start and will not allow me to program keys. Aketokediag are you on Skype ?
  18. #15
    Jul 2015
    ofcourse yes am on skype you can pm yours
