Results 1 to 7 of 7
    levisdj's Avatar
    EcuLand
    Default Renault Trafic P062F Error
    Hi, got a problem with this car, 0281014648 ECU.The P062F Internal EEprom error.Tryed another ECU cloned by BDM, same thing.Anyone got a sollution ? I attached fullbdm M58 and EEprom.THanks.Also i have the full bdm from the spare part that's another BOSCH part number, 0 281 012 658 . Is it possible to virginise E2p from this ECU and try it on ? Any help is useful!
    kinketotua's Avatar
    Apr 2016
    Europe
    I think these solved with renault clip.
  3. The Following User Says Thank You to kinketotua For This Useful Post:
    levisdj (10th June, 2016)
    levisdj's Avatar
    EcuLand
    I see... but I don't have Renault Clip... another idea ?
    kinketotua's Avatar
    Apr 2016
    Europe
    I think the only way is with clip, and then coding inyectors. Good luck
    levisdj's Avatar
    EcuLand
    I have a previous read of the injectors configuration, read by Galletto 2... maybe a virgin E2p and re-writing the injector file may solve the issue ? Perhaps someone can provide a virgin file here please.Thank you
    Senior Member Novik_UA's Avatar
    Have few time such problem, and with Clip is easy to repair. You need just read ECU config in repair mode , and then write it back. Find someone with Clip and problem gone.
    Feb 2018
    Colchester UK
    Please anyone can recalculate checksum for Renalult master THX in advance
