ECU: 03L 906 018 HH
Engine: CFFB
Need to DPF OFF and ADBLUE OFF - best Swiftec solution
MANY THANKS !!!
ECU: 03L 906 018 HH
Engine: CFFB
MANY THANKS !!!
If my solution helped You - do not forget to THANKS !!!
here
-->SHARAN_dpf_adblue_chck.rar
number7hd (16th June, 2016)
I will report later - tHanks !
it' not OK ..
Well - I think it's not OK - after few days of using a Car there shows 2 fault:
P245600 Diesel Particulate Filter Differential Pressure Sensor Circuit Intermittent/Erratic
As I know - if DPF is removed in EDC17 correctly - even if this sensor is disconected - ECU shouldn't report that - am I wright?
here
unplug diferencial sensor pressure
also I disable EGR
--> SHARAN_dpf_adblue_V2_chck.rar
number7hd (30th June, 2016)
Intflash.rar - is the ori file
SHARAN_dpf_adblue_V2_chck - is dpf off file
Please give me a pass.
Attachment 411101Hi. I dont remember the pass. I make another time for you
