swap the file !!!
Attachment 383006
swap the file !!!
Attachment 383006
pazzoide (24th June, 2016), pekelan (9th January, 2021), yellowstilo (24th June, 2016)
I did not understand what you mean by swap.....
11 22 33 44 swap result 22 11 44 33 ?
and then I do not understand how you can convert
52c3c64c to 24336
If you do not understand that mate .. give up take up woodworking ....
djollie (23rd June, 2017)
friend to me it says ... learn the art and put it aside.....You can always serve one day
No mate .. it says Byte swap ...
THANK YOU SO MUCH GOOD FRIEND. I HOPE TO BE USEFUL TO YOU
@bulanbulanov
Please do not bother,
failing to even button press, not to mention the reputation ....
and here lazy to look for the forum ....
Everything must be on the plate ....? And chew ....
A topic that interests me
I do not understand what you mean Friend @DK Veteran
I'm just trying to figure out quickly....so you know what I mean when I talk.
I hope it is not a problem!
I noticed that some files are not to be swapped....What occurs? to know if it did swap?
look at my file i posted - when you can read the tester code ( "OUTPUT-JIT") the file is decoded correctly.
Otherwise swap the file.
I sensed this thing
hello....can you explain me please how you decrypt this file ? I mean the whole process. Thanks
i already explained you by PM but if you do not understand the previous pages you have to learn more about some basic things first - i also learned by reading a lot and trying things until i understand how it works - not everything is presented as a ready-cooked meal, you have to do some effort yourself too after you get so much information for free here....
good luck !
