Results 1 to 15 of 16
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default edc15 KLine kess v2 pins seat
    hi, l have this to read on bench but cant fine kline in kess anywhere , in this video you can see it connected but l cant make out the pin numbers
    cheers
    sorry l must be colour blind . the one wire looks yellow but it must be green ..
    carry on to someone elses posts
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Pin 16 = K-line
    Pin 1,2,37,88 = "+"
    Pin 4,5 = ground
    Cheers!
    Sorry, i just looked at this video later... maybe his harness is different... the most important is, that the pinout is right.
  3. The Following 2 Users Say Thank You to bobolin4o For This Useful Post:
    longgo (3rd October, 2018), smirnoff_rules (8th July, 2016)
    Mar 2008
    birmingham
    tried this today , dosnt work lm sure its bull~~~~ , unless someone heres done it
    Jun 2013
    EU
    I've done it before with that same pinout but with fgtech. 100% works.
  6. The Following User Says Thank You to morgano For This Useful Post:
    Jun 2013
    EU
    Made the test for you with one of my kess clones.
    Look.
    Used fgtech harness to duplicate feeds as the cable from kess just had 2 thin red wires and needed at least a faston to feed the ecu, but you can see it is working.
  8. The Following 2 Users Say Thank You to morgano For This Useful Post:
    bobolin4o (9th July, 2016), smirnoff_rules (9th July, 2016)
  9. #6
    Mar 2008
    birmingham
    cheers m8 ,, good work , l did try again and kess dosnt send power to the red wires when reading but does on other ecu types ?, when l get back into work l will try with powering the ecu up from another supply ,,
    kess wiring l have does have 3 12v feeds tho
    looking at the youtube video his earth and power look like they might have different spades
  10. #7
    Jun 2013
    EU
    On the video i have used not tricore module adapter which efectively not power the ECU and use yellow wire as Kline, i have used the PCR2.1 cable, it powers ecu by the switch and uses green wire as Kline
  11. The Following 2 Users Say Thank You to morgano For This Useful Post:
  12. #8
    Junior Member mariuso2o's Avatar
    May 2018
    is this a correct way to connect kess to edc15p+? 37766465_1882904325086840_4642782376219377664_n.jpg
    left side goes to ecu pins, other wires go to power suply and right one to laptop
  13. #9
    Jun 2013
    EU
    No, not correct way, that addon is tricore bootmode module, not good for edc15p bench reading.
    Use the one included to unlock pcr2.1
  14. #10
    May 2018
    37815058_1883013048409301_7547208904392835072_n.jpgIm really having a hard time with all these adapters because there is no names on them.. but maybe you talking about this? it has a switch and power cables.
  15. #11
    Jun 2013
    EU
    Quote Originally Posted by mariuso2o View Post
    Exactly, that one is “the one”.
  16. #12
    Jun 2013
    EU
    As i explained before, use that adapter, red, black, and green wire for kline. Switch to simulate key on/off.
  17. The Following User Says Thank You to morgano For This Useful Post:
    mariuso2o (24th July, 2018)
  18. #13
    dominik.m's Avatar
    Jun 2009
    POLAND
    EDC15P , EDC15P+ , EDC15VM ..... from VAG group pinout is the same.
  19. #14
    Sep 2018
    Earth
    Unhappy
    Quote Originally Posted by morgano View Post
    Well, seems I`m Myrphy`s loyer or brother because with exact same cable... and EDC15P+ from 1.9TDI PD 99`sh VW no luck at all...
    Just to mention, via VAG COM in the car can read data(channels) from it.
    So I connect first:
    Pin 16 > K-line (using the green wire)
    Pin 1,2,37 > "+" , using bench 12.8V supply
    Pin 4,5 => ground
    "Unknown ECU error" was the message kess show and that`s it.
    Then try over the top post suggestion:
    Pin 16 = K-line (green cable)
    Pin 1,2,37,88 = "+"
    Pin 4,5 = ground
    Nope.. Same error
    As last, so far I found info the yellow is K-line.. , so I try with the yellow one...
    Again.. no happy kid..
    Perhaps when manage to "kill" the immo, I`ll try to fit it back in the car and test using the OBD plug.. but still any chance to be some "hidden" rock?
  20. #15
    Jun 2013
    EU
    You need to feed from same source kess and ecu, in fact you should feed kess, and kess should feed ecu via the on off switch.
  21. The Following User Says Thank You to morgano For This Useful Post:
