    Sep 2015
    Default Renault kangoo Imm off 0281010502
    Does somebody have tested solution for Immo off 0281010502
    24c04
    1.9dti
    24c04 kango orginal.rar
    Thanks!
    Jun 2013
    Lithuania
    Hello, I attach immo off file, but before you do anything you need to buy fresh EEprom with write protect - 24C04WP, write this dump, lift EEprom 7 leg and join it with 8 leg of EEprom Can't tell 100 % if you need to disconnect immo wire, but if yes, then cut 15 pin wire . In the picture you can see that you need to lift 7 EEprom leg from pcb and attach it - solder it to 8 leg of EEprom.
  3. The Following User Says Thank You to Milicija For This Useful Post:
    MARIKO (16th September, 2019)
    Sep 2015
    Hello thanks for reply
    But this is not MSA 15.5 and picture of pcb is not the same as my pcb.
    Regards,
    Jun 2013
    Lithuania
    picture is for better understanding... you can read this post for more information http://www.digital-kaos.co.uk/forums...DTi-0281010502
    lion0304's Avatar
    Oct 2014
    Default EDC15 OFF
    Quote Originally Posted by hbt View Post
    24c04
    1.9dti
    Thanks!
    I have OFF solution for this ECU, but you need mod eeprom and put Emulator.
    Cut pin 15, connect Kline Emu to link 15.
    12V Emu to pin 81
    GND Emu to pin 4 + 5. Working 100%
    24c04 kango OFF.rar
    No THANKS, no HELP!!!
  7. The Following User Says Thank You to lion0304 For This Useful Post:
    hbt (20th July, 2016)
  8. #6
    Sep 2015
    Quote Originally Posted by lion0304 View Post
    12V Emu to pin 81
    24c04 kango OFF.rar
    Hello what is the Pass??
