Results 1 to 11 of 11
    lmsvvavr's Avatar
    United Kingdom
    Default Nissan Juke F15 ABS C1130 code
    Hi guys!
    I have this 2012 Nissan Juke F15 with the stability control light permanently on...
    When scanned, the only ECU reporting an issue is the ABS, showing the code C1130, engine signal 1.
    I checked the can line at the ABS plug, and got the reference value as per nissan documentation.
    I then bought a second hand ABS unit, changed it, and done a steering angle calibration.
    Now the code came back straight away...
    As I said there is no codes on any other ecu...
    Does anyone have an idea of what can be causing this?
    Thank you
    Hit Thanks if helped you!
    Thank You for the help!
    "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
    http://www.youtube.com/c/LMAutoRepairs
    Jun 2014
    Accra
    disconnect the ABS cord on the ABS sensor after diagnosis and clear the fault code.
    after that reconnect and start car. done
    lmsvvavr's Avatar
    United Kingdom
    Quote Originally Posted by Baidoo View Post
    HI
    I am bit confused...
    Which sensor should I diconnect?
    lmsvvavr's Avatar
    United Kingdom
    Doesn't work...
    Your speedometer is malfunctioning i think... bcz , I got the same issue before..
  6. The Following User Says Thank You to sajeevandna For This Useful Post:
    ChipDoctor (19th October, 2019)
    nbtechnic's Avatar
    Jan 2016
    Hello, various Nissan models generated random default and completely wrong codes. Many owner of this brand are very disappointed because of these electronic fault. Even nissan does not include these random defects, some have a ecu the update by Nissan and the problem was solved, the other did the update the fault code For troubleshooting returned.
    Dec 2010
    Check wire of sensor carefully you can see that inside one of two wires are partial cut
  9. The Following User Says Thank You to mitch2 For This Useful Post:
    nbtechnic (27th August, 2016)
  10. #8
    cjawahir's Avatar
    T&T
    Quote Originally Posted by lmsvvavr View Post
    Hi guys!
    Thank you
    hello look at the pdf file .
    http://repairdata.cnlaunch.com/pdf/2...d05026822b.pdf
    cj
  11. The Following 3 Users Say Thank You to cjawahir For This Useful Post:
    mcm44 (4th July, 2017), nbtechnic (29th August, 2016), vanos batam (29th August, 2016)
  12. #9
    Jun 2016
    LTU
    Hi guys!
    Thank you
    You solve this problem?
  13. #10
    Nov 2010
    Hi guys!
    Thank you
    Hi, solve this problem?
  14. #11
    lmsvvavr's Avatar
    United Kingdom
    Ended up replacing the engine module....
    That solved the problem...
  15. The Following User Says Thank You to lmsvvavr For This Useful Post:
    efiman (22nd September, 2021)
