Results 1 to 11 of 11
    Nov 2013
    UK
    Default Toyota Corolla Need dumps for ECU 89661-02a61 93c86 and 89780-12160 IMMO 93c56
    Toyota Corolla Need check dumps for ECU 89661-02a61 93c86 and 89780-12160 IMMO 93c56
    Does anyone have paired dumps for this? Is anyone able to check if the ECU dump is ok?
    I checked car and found transponder damaged, I made new transponder with AVDI original TagKeyTool and then immo light goes off but car does not start...
    I diagnosed the car and inside ECU is code B2799, so I bridged pins 4 and 13 for 35minutes twice... now the car started few 3 seconds and then cuts out... the fault code inside ECU is still B2799 but car starts and dies before it was not starting at all... any ideas?
    ECU dump is attached, please help me...
    DONT FORGET TO LEAVE THANKS + REP!!
    DPF, EGR, O2/LAMBDA, ADBLUE, VMAX/SPEEDLIMIT, CHIPTUNING FOR PETROL/GASOLINE AND DIESEL VEHICLES!
    EDC17 VAG IMMO OFF, ECU CLONING, BMW EDC17 ECU CLONING!!!
    Brayn's Avatar
    Oct 2015
    Colombo
    I think your key not succefuly programmed. Try again using avdi or any other tool. Key programing successful, immolight goes off but only car start for 3 seconds
    That mean key not programmed successful
    Sent from my C5502 using Tapatalk
    Brayn's Avatar
    Oct 2015
    Colombo
    Post your immobox data
    Nov 2013
    UK
    Please see attached the immobox data, I attached before and after adding of the key... I used a virgin 4c chip... would that cause this problem?
    TM100's Avatar
    Jun 2016
    your Toyota is what year?
    Nov 2013
    UK
    2005 corolla
    TM100's Avatar
    Jun 2016
    change your eeprom the 93C86
    Nov 2013
    UK
    Quote Originally Posted by TM100 View Post
    Change the data inside eeprom or replace the actual physical eeprom?
    Immo is original , it's not changed ?
    TM100's Avatar
    Jun 2016
    Find the dump ECM 93C86 for that car and replace it if it does not start to be replaced eeprom
    Jul 2018
    Espaņa
    Default Toyota Corolla With Fault B2799 No Start
    Hi mate!
    How you solved it???
    I have a dtc B2799 in ecu and car doesnt start..
    The ecu is a denso 89661-02A60 with eeprom 93C86.
    I post the dump too.
    Can you help me please?
    Thank you
