Page 54 of 147 FirstFirst ... 444495051525354555657585964104 ... LastLast
Results 796 to 810 of 2193
Thread: nats 5 pin code
  1. #796
    GB
    Hallo i need pin code for nissan cabstar nats 5/5.6 made in germany type B 5WK4 8042A_R 23413A 5619
  2. #797
    DK Veteran mburu's Avatar
    Sep 2010
    Default I need Nissan supercode serial No.
    Quote Originally Posted by grezacediagnostics View Post
    Try this. the new nissan supercode
    Dont forget to say thanks
    Hi, please send me the serial no. for the super code software.
  3. #798
    GB
    serial for the supercode software is : F7E92B1M
  4. #799
    UK
    code 1616
  5. #800
    Top Poster Dylan Chin's Avatar
    Aug 2010
    Quote Originally Posted by radu_stoica78 View Post
    try pin 1616
  6. #801
    Member twardy12345's Avatar
    Norway
    Hello
    somebody can help , i need pin to primera
    28596 av3
    siemens made in europe
    5wk4 8127
    SPLS/RX-9/2001
    04034931
    433MHz
    Ref.5WK4 8812
    125KHz
    Ref.5WK48124
    Csk e1 AI-00042
    E1 97RAI-000013
    MCW 129/95 21/2001
  7. #802
    Sep 2011
    south africa
    Quote Originally Posted by slavisac View Post
    This is the one rambit
    5wk4 8644a r94112
    Thank you in advance
    Try 3307 ....hit the thanks tab
  8. #803
    Sep 2011
    south africa
    Hi try 0176 or 1760..report back please
  9. #804
    Sep 2011
    south africa
    Quote Originally Posted by twardy12345 View Post
    Hello
    28596 av3
    5wk4 8127
    SPLS/RX-9/2001
    04034931
    433MHz
    Ref.5WK4 8812
    125KHz
    Ref.5WK48124
    Csk e1 AI-00042
    E1 97RAI-000013
    MCW 129/95 21/2001
    please post label of immo ring AROUND IGNITION please...thanks
  10. #805
    Norway
    Quote Originally Posted by rambit View Post
    Label ring:
    Siemens L
    28590 C9965
    Made in mexico
    5wk4 8043c
    408140 this nr under line code
    91LP0158
    somethings else?
  11. #806
    DottoreBL's Avatar
    Bosnia
    Default Need help ?!
    Need help ?!
    I need to go out of my town to program new keys for Murano 2004, and i found this near ignition lock. Can someone caliculate pin code for me ? I have Nissan Super Code Caliculator but i do not know what 5 digits to enter ...
    And is it chip 46 for this Murano or 60 ?
    4f 54 54 4f 52 45 20 45 4c 45 43 54 52 4f 4e 49
  12. #807
    malczykos's Avatar
    POLAND
    Please calculate PIN code for Murano 2004
  13. #808
    Sep 2011
    south africa
    Quote Originally Posted by malczykos View Post
    TRY 2880 OR 7616 .. PLEASE HIT THE THANKS TAB ON UR WAY OUT....
  14. #809
    Sep 2011
    south africa
    Quote Originally Posted by DottoreBL View Post
    Need help ?!
    please check malcs post below ures...use the 5 digit serial below lot no...for supercode..easiest way to identify chip will be to do manual program of remotes..turn ign from off to on 6 times ending in off.do not remove key..if hazards flash then it will be id 4d60 if it doesnt then it will be id 46..hope this helps
  15. #810
    Sep 2011
    south africa
    Label ring:
    Siemens L
    28590 C9965
    Made in mexico
    5wk4 8043c
    91LP0158
    somethings else?
    what are u using to code keys?t300 sbb \consult?
