Results 1 to 11 of 11
    soxten's Avatar
    Mar 2013
    Default How to know, 8 or 16 bit read on 93C66 Eeprom?
    I have a UCH from Renault Clio (Sagem) as having 93C66 Eeprom
    This Eeprom I can read 8 or 16bit.
    How do I know what bit I need to read?
    Is there any way to know and understand if it should be 8 or 16 bit read?
    ex Saab CIM with 93C66 I read as 8bit and it works perfect.
    Jan 2016
    South Africa
    Easy way to tell : read as 8 and the 16, save your files , try write 8bit back to eeprom and see if data has written same , if verify has success then it is 8 bit if you have errors then its 16 bit
  3. The Following 3 Users Say Thank You to gjenkins0 For This Useful Post:
    qbkfmfnt (20th February, 2025), scoot (26th October, 2018), soxten (16th August, 2016)
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    there you go...
    *looks like the pict posted too small to be read here it is what's written in pict : Pin 7 is tied to pin 5 that makes a 8bit. Mode read.
  5. The Following 8 Users Say Thank You to ucokseparoh For This Useful Post:
    antotechaustin (18th January, 2018), bearheroes (16th August, 2016), bhimanathanael (24th September, 2024), HeXeN (21st August, 2016), ibratex (17th August, 2016), maremuruk (17th August, 2016), SERGE5194 (12th April, 2021), soxten (16th August, 2016)
  6. #4
    soxten's Avatar
    Mar 2013
    If I understand correct.
    This is 8bit (Saab 9-3 CIM 93C66x8)
    And this is 16bit (Sagem UCH Renault Clio 93C66x16)
  7. The Following 13 Users Say Thank You to soxten For This Useful Post:
    antotechaustin (18th January, 2018), capi (29th September, 2022), Col19 (5th April, 2023), DDex (1st March, 2020), fatus0 (7th December, 2022), HeXeN (21st August, 2016), ibratex (17th August, 2016), just4upal (17th August, 2016), myma7up (7th October, 2021), qbkfmfnt (20th February, 2025), rabronzatto (26th March, 2025), sinanorhan (10th October, 2020), teeone (19th September, 2016)
  8. #5
    ray-ray's Avatar
    Finally someone understood (EEPROM is 8 or 16 bit off the board) once on the board if pin 7 is tied to pin 5 then read as 8bit mode. In the USA we read in circuit so alway check pin 7 & pin 5 to get the right read.
  9. The Following 5 Users Say Thank You to ray-ray For This Useful Post:
    antotechaustin (23rd September, 2017), HeXeN (21st August, 2016), ibratex (17th August, 2016), maremuruk (17th August, 2016), Nikola1309 (18th September, 2016)
  10. #6
    I think you meant pin 6, org pin.
  11. The Following User Says Thank You to Zmann For This Useful Post:
  12. #7
    city
    read 8 bit.
  13. #8
    ray-ray's Avatar
    Correction 6&5 org.&ground = 8bit.
  14. The Following 3 Users Say Thank You to ray-ray For This Useful Post:
    antotechaustin (18th January, 2018), DDex (1st March, 2020), fatus0 (7th December, 2022)
  15. #9
    soxten's Avatar
    Mar 2013
    Can I use this to understand all type of Eeprom like 93C56/C66/C76/C86 etc?
    ImageUploadedByTapatalk1471382559.180764.jpg[/QUOTE]
  16. #10
    Aug 2015
    Yes, pin 6 Org (organization off structure ).
    Level HI or Low respective 16 bit or 8 bit
  17. #11
    Jan 2016
    Quote Originally Posted by gjenkins0 View Post
    buddy this not make sense to me.
    is you write 8bit back , it will verify with 8bit read and not with 16bit
    same way, if you write 16bit back, it will verify with 16bit and not with 8bit
    Or maybe I have not understand your point ?
