Page 1 of 4 1234 LastLast
Results 1 to 15 of 48
    adam28's Avatar
    May 2009
    UK Essex
    Default nissan supercode
    Nissan supercode calculator
  2. The Following 65 Users Say Thank You to adam28 For This Useful Post:
    aimen96 (30th November, 2021), antwnhszr (26th November, 2019), b5bus (11th December, 2020), bartikos79 (4th June, 2019), benzstop (23rd May, 2013), Brycedow (18th November, 2021), BusCan (20th February, 2018), cartronic (8th April, 2016), ciptel07 (17th April, 2015), cole_mcs (14th May, 2015), csavargo2 (17th January, 2014), danielboom00 (23rd March, 2014), daquima (21st September, 2016), DOUGLASDL (25th September, 2017), dukeofcarabas (14th September, 2022), ecufix (2nd June, 2014), eeze (12th January, 2018), electronicar (23rd November, 2018), Foxsitto (22nd June, 2019), fronzethenight (3rd February, 2025), Gery (12th March, 2016), godfathertre (16th July, 2016), gogoli (22nd December, 2014), gordonjairo (18th December, 2020), habbyb (17th January, 2017), hanrios (30th March, 2024), jenny123 (30th September, 2013), KennySmit (2nd July, 2014), Klimek (16th July, 2016), kredka74 (17th January, 2020), lumetan (11th July, 2022), malakas32 (2nd February, 2017), MAMBOKING (11th June, 2023), mancinofranco (24th March, 2016), maremuruk (24th August, 2016), mariantv (13th July, 2022), marsete (25th May, 2015), MOBILTRONIC (27th January, 2018), mreguest (15th August, 2023), n599fbm (17th March, 2014), pedro222 (25th August, 2016), pezao (13th January, 2016), pouleddy (20th May, 2024), purdy (27th August, 2015), Randomqwerty (28th February, 2019), Rasmus (17th May, 2023), rob h (9th July, 2017), roycefus esq (20th April, 2020), rtbdiagnostic (19th October, 2022), Sam-F (12th February, 2021), sasa5 (16th July, 2016), SebasCM (20th June, 2024), shanektm450 (31st August, 2015), Shawnv6 (4th January, 2024), shtyrya2 (9th June, 2014), stanislav georgiev (7th December, 2016), tallwombat (7th October, 2019), thibault68 (29th November, 2020), vomit (26th October, 2014), weza247 (1st April, 2016), workshop bot (5th June, 2019), xandov (11th July, 2013), xifly18 (30th September, 2015), zemaitis (15th November, 2019)
  3. #2
    DK Veteran ivica's Avatar
    Apr 2009
    What is the serial m8?
    regards
    adam28's Avatar
    May 2009
    UK Essex
    look in log file text. And you find this. F7E9 2B1M
  5. The Following User Says Thank You to adam28 For This Useful Post:
  6. #4
    Apr 2009
    Found!
    thanks m8
    Ferizaj KOSOVA
    Default NISSAN pincode
    Is this like Nissan NATS5 pincode read software or like nissansupercode software?
    how can i get this download plz
    Nikicom locksmsith shop
    Ferizaj KOSOVO
  8. #6
    adam28's Avatar
    May 2009
    UK Essex
    Quote Originally Posted by nikifer View Post
    Ferizaj KOSOVO
    converts 5 digit serial to 4 digit pin
  9. #7
    coolsoda's Avatar
    Apr 2008
    Scotland
    Default Usable serial
    I downloaded this a while ago from Mininova,and need a serial,there is none in the logfile text,
    anyone help
  10. #8
    adam28's Avatar
    May 2009
    UK Essex
    Quote Originally Posted by coolsoda View Post
    anyone help
    Read post 3 in this thread mate
    NEVER GET SO BUSY MAKING A LIVING THAT YOU FORGET TO MAKE A LIFE......
  11. #9
    twister2000's Avatar
    I have the same serial but it not works
  12. #10
    Quote Originally Posted by twister2000 View Post
    could you give us the serial number plz
  13. The Following User Says Thank You to tayab_44 For This Useful Post:
    aneudililly (26th April, 2014)
  14. #11
    https://t.me/pump_upp
    Quote Originally Posted by tayab_44 View Post
    S/N : F7E9-2B1M
  15. #12
    Car235's Avatar
    Quote Originally Posted by bnad3m View Post
    S/N : F7E9-2B1M
    Delete irunin.ini and try again !
    Good luck !
  16. #13
    UK
    I have tried nissan supercode on several uk nissan primeras and almeras ,NATS5, and found that the code from the 5 digit serial number is different from the correct one.
    I think it will only work for american cars whose immobeliser(BCM) is made in Mexico.
    UK cars have immo made in Germany. Certainly there is software out there that people like Advanced Diagnostics use.
    I would like to hear from others who are using Nissan SuperCode OR any other software to get pin codes for NATS5 UK Nissans.
  17. #14
    Where do u find the 5 digit serial on car??
  18. #15
    UK
    Open the top couling to the steering coloum and you will see immo box next to ignition switch. Serial number is between bar codes , EXAMPLE, 5WK4 8042A_G11924A .
    In this case your serial number will be 11924
