Hi All,
trying to get some opinions on this fault, I have posted in other forums, so you may see this post somewhere else...
Having a bit of a problem with a Peugeot 308 MY 2008 petrol Prince engine EP6C and would appreciate your view and advice.
The fault I?m getting is:
P0014 Exhaust Camshaft Phasing Coherence Permanent.
The vehicle starts but after it warms up it runs really rough. actually now it runs rough from cold.
All the info I read, points to the VCT solenoid that controls the Exhaust Camshaft timing being faulty, so I fitted a new one but it made absolutely no difference. Then I thought maybe the camshaft sensor for the Exhaust camshaft is faulty so I fitted a new one of those too, no change whatsoever.
After looking for a bit more info online, it is obvious that this fault can have a multitude of causes, from wrong oil, to VCT mechanism fault. This is a pain as I don?t really know the history of the vehicle...
I decided at this point to scope the signals to the VCT, links for the pictures bellow:
At Startup
https://drive.google.com/file/d/0BxO...ew?usp=sharing
At Idle
at high revs
Scope traces for the Exhaust Camshaft sensor:
The strange part was that I managed to get the vehicle to run a couple of times well, not sure how but it did and the scope traces are the result. Please bear in mind that the waveforms are inverted.
On normal engine run, when the engine starts, the solenoid is at rest and the ECU is commanding it to start at around 10% duty cycle, then immediately the ECU varies the Duty cycle to around 50% and it stays like that at idle. As soon as I rev the engine the ECU commands the Solenoid to move from 50% up to around 90% duty cycle.
When not running correctly, the ECU is keeping the VCT solenoid signal always at start up position.
Armed with this info, I decided to try to prove that the VCT solenoid/oil/cam mechanism was working correctly. I measured both the new and old VCT?s internal resistance which was around 8 ohms and fitted a resistor of the same value in the connector coming from the ECU. This way the ECU will think that the Solenoid is still connected and not come up with another fault.
I then, using an Arduino board with a motor control shield, built a rig to drive the solenoid independently with the same voltage/current and the right duty cycle. This actually worked very well!
I started the vehicle and it was running rough, I then commanded, using my rig, the VCT solenoid to move to around 60% duty cycle and immediately the engine got the revs slightly higher and it run perfectly. Even when I rev it up, it was fine, not sure about efficiency and emissions, but it run fine.
Now, at this point I was expecting the ECU, as it is seeing the solenoid move independently of its control, would try to control but the ECU trace on the dummy solenoid never changed.
My understanding of the fault reported by the ECU is that when trying to control the VCT solenoid to a certain position, the camshaft sensor signal is not as expected. I think it is most likely comparing that signal with the crankshaft sensor signal to get the phase angle that the camshaft moved to but somehow it is not correct. Please correct me if I?m wrong.
I was a bit surprised with the camshaft sensor signal (see waveforms above). I was expecting a regular square wave signal, so at first I thought that was the problem, but after fitting a new sensor the signal was the same. I also scope the inlet camshaft sensor and the signal is similar so can only conclude that the signal is fine. It looks like some kind of PWM that in analogue terms with result in some sinusoidal signal. That sort of makes sense as it will help the ECU compare it with the crankshaft sensor signal.
I am heading for a diagnosis of a faulty ECU, but I am still not convinced? I am going back to the vehicle and scope the crankshaft sensor and compare it to the camshaft sensor to see if I can see anything unusual.
I would like to discount the ECU fault by completely clone the ECU to another used one. Unfortunately this vehicle is using the Bosch MEV17.4 ECU, which I have no kit to clone it with. I have a couple of programmers UPA, XProg and the FGTECH GALLETTO V54 but looking at info online this ECU has boot option disabled at the factory. If someone as a solution for this, it would be great. If it is possible to code a used ECU to the vehicle I would also be interested, I do have PP2000.
ECU:
If any of you have any other ideas or suggestions for fault finding, it would be appreciated.
Thank you.
Best Regards
ET
