    Nov 2015
    Default BMW E36 M3 - Need change MILES to KM in VDO cluster
    Hello.
    I need to change milage - from MILES to KM in cluster from BMW E36 Mpower. Cluster is from 95/96 year, numbers:
    VDO 110.008.463/099
    BMW 62 11-2 259 466
    Inside i found one 93S56. Is it possible to change miles for KM in this cluster?
    I have xprog, carprog, digiprog, upa..
    I found info that deeper in cluster is second 93S56. Need I read both of memories?
    And more numbers from inside:
    992 648 595 S
    SW:20
    HW: 6.6
    L 94
    KW 19
    And here is DUMP:
    93S56_SW20_E36_m3_dash.rar
  2. The Following User Says Thank You to stachu22 For This Useful Post:
    sepp0 (24th November, 2017)
  3. #2
    Nov 2015
    Anyone can help me? Maybe somebody have dump from similar cluster?
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    In european clusters change miles/km by buttons on the odometer, but english ... try ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
    Nov 2015
    There is no option to change it by ODO, only replace dump
    Got this dump here of a 1995 euro e36 m3 3.0l. It's a kilometer dump. Maybe this will help you.
    Coversion could also be done by coding the KOMBI. But to connect to the KOMBI you need a proper interface (ADS;Diaghead;ICOM)
  7. The Following User Says Thank You to o-dog For This Useful Post:
    stachu22 (5th September, 2016)
  8. #6
    Nov 2015
    Thanks! Cluster works great!
