Results 1 to 15 of 17
    Sep 2015
    Warszawa
    Default Nissan Terrano Immo problem
    Hi, Can someone help me with immo off on old Nissan Terrano Bosch Ecu 0281001550 inside 24c02 eeprom or sugest my some diffrent idea . Please
    Sep 2015
    Warszawa
    It's Nissan Terrano 1999 2.7 TDI engine
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    make keys its easy than make immo off
    make key or use emulator
    Sep 2015
    Warszawa
    coud you explain how to make key or immo off as i am really stuck with this car i have tried various dump files from forum but nothing works, car wont start at all. when i remove immo eeprom from ecu car starts and runs for few seconds and than just cuts off. looked on internet but cant seems to find any emulators for it ..... if someone got working solution i can pay for it.
    many thanks
    Sep 2015
    Warszawa
    Someone Please ?
    avital's Avatar
    I send to PM info about company which produces emulator for this system immo.
    Oct 2015
    Quote Originally Posted by karlo866 View Post
    Someone Please ?
    Do you have t300 or avdi ?
    Sep 2015
    Warszawa
    working solution for this car if someone gonna need
  10. The Following 42 Users Say Thank You to karlo866 For This Useful Post:
    Adi202 (6th April, 2020), alex64 (7th October, 2022), aprilia40 (11th January, 2023), ascotauto (12th August, 2019), biela (13th April, 2025), CIRCUIT.FR (13th October, 2017), CoeraPejo (7th February, 2018), dimet (12th September, 2018), eeprom241 (14th May, 2018), elitricista (12th May, 2021), esse (25th February, 2020), ezzobg (3rd February, 2023), gobe (13th September, 2017), Helix (7th September, 2019), hellmet (22nd November, 2022), hrmotorsport (9th September, 2022), Kalectro (27th July, 2021), kenrique10 (19th February, 2021), kobelco (17th April, 2018), konop11138 (12th June, 2018), krisdiv (11th March, 2021), lion0304 (28th August, 2019), mariazo84 (31st January, 2019), Mario3 (5th March, 2022), MARVAL (28th July, 2020), Mk developments (3rd November, 2020), Mr BLACK (30th May, 2022), pedrodiaz (26th December, 2017), pipina (26th February, 2018), rch11 (13th November, 2021), rsologubov (21st September, 2023), sergiodc (10th October, 2020), sonho1999 (13th February, 2020), stevan (17th February, 2020), tmkz (26th August, 2019), toni_18674 (26th November, 2020), tor2lehel (10th January, 2018), tugay123 (18th March, 2021), vdiag (17th September, 2021), yasser (14th June, 2023), zottika (10th April, 2018)
  11. #10
    Aug 2011
    hi, thank you. work for me too.
    regards
  12. The Following User Says Thank You to pipina For This Useful Post:
  13. #11
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Where ecu are located? Don't have car there and client can't find where is ecu. Thanks.
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  14. #12
    DK Veteran mariazo84's Avatar
    bajo pies right
  15. #13
    [CITA = Saulius Saulius; 3485735] ¿Dónde están ubicados los ecus? No tengo coche allí y el cliente no puede encontrar dónde está la ecu. Gracias. [/ QUOTE]
    under feet right up
  16. #14
    tmkz's Avatar
    Sep 2010
    PL
    this file work me to!
  17. #15
    Nov 2015
    Bulgaria
    easy solution for this ecu just modify adresses 036 037 056 tested many times orig file only and remove immo box.
    Bulgaria
