Results 1 to 8 of 8
    Oct 2014
    romania
    Question ford eec v repair
    i have a ford mondes year 1998 ,1.8 petrol and i have made immo off ,because the car wont start ,but now i dont have spark on the plugs ,gasoline is coming but no spark ,what should i check ,i have changed the down sensor...but nothing
    Act Tuning's Avatar
    Sep 2016
    Around
    Mybe you didnt remove immo , did you scan the car for faults ??
    CVN FIX Vag/Bmw
    Tuning Petrol and Diesel
    High Power Maps
    Custom Tuning Stage 3+ Hybrid
    Dsg Tuning
    Oct 2014
    romania
    i have soldered pin 4 with pin 13 ,is same method,the car engine wont turned before i did immo off ,now it turn...
    Act Tuning's Avatar
    Sep 2016
    Around
    If you sure about immo, then it simpale, rev the engine and if you can see rpm on scanner, check with led light on ignition coil if ecu send command, or you dont get rev in scaner ?
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
  5. The Following User Says Thank You to Act Tuning For This Useful Post:
    BoNzOtM (12th September, 2016)
    Jan 2012
    EU
    if ecu/immo off is ok, Zetec: once I had bad coil+ignition wires -> no spark at all. I needed to change coil+ignition wires.
  7. The Following User Says Thank You to Aajii For This Useful Post:
  8. #6
    Oct 2014
    romania
    voltage is coming to the ignition coil ,but i dont have spark on the plugs...strange,i changed the ignition coil ,but i havent changed the wires
  9. #7
    Act Tuning's Avatar
    Sep 2016
    Around
    Quote Originally Posted by BoNzOtM View Post
    If voltage is comming, so 100% replace the ignition wires, but before you start remove the spark plugs and clean them cause they will be wet now, as you try rev the engine and no spark, clean+replace wires and start the engine,
    CVN FIX Vag/Bmw
    High Power Maps
    Dsg Tuning
  10. #8
    Oct 2014
    romania
    all ignition wires are broken,thank you
