Results 1 to 15 of 17
    Jul 2016
    Belgium
    Default Immo SIEMENS DME MS42
    Need immo + egr delete
    SIEMENS DME MS42 5WK9037 Index 04 700 255 M52 EWS 3
    EWS-DME Sync code = 9F46
    DME_MS42ORI.zip
    Thanks in advance
    Jul 2016
    Belgium
    Could someone help me out please?
    Did i get the wrong file from DME ( downloaded the bin file with BMW Scanner 1.4.0 file size = 512kb)
    I have tried to get 29F400 in boot mode by grounding pin 104 for 6sec when power is switched on.
    When i did a read with galletto the file still was 32kb.
    Thanks in advance
    Apr 2016
    you choice "AUDI VW ME 7.x.x 29F400BB BOOT PIN 24 FLASH A MAS" to read the file in bootmode.
    The file was 512Kb.
    Best regards.
  4. The Following User Says Thank You to AutoExe3219 For This Useful Post:
    Stijnvdw (15th September, 2016)
    kiszka's Avatar
  6. The Following User Says Thank You to kiszka For This Useful Post:
    Jul 2016
    Belgium
    So if i understand correctly, i need to locate pin 24 on flash 29f400 and ground it foor 6 sec on power on.
    Then select audi/vw file in gellatto to read flash? If i wan to write to the flash i must do the same?
  8. #6
    Jul 2016
    Belgium
    I think it worked
    ms42flash29F400ori.zip
    Is this the correct file?
    Thanks!
  9. #7
    Jul 2016
    Belgium
    Could someone do immo off please?
  10. #8
    Apr 2016
    Here you go
    Best regards.
  11. The Following User Says Thank You to AutoExe3219 For This Useful Post:
    Stijnvdw (18th September, 2016)
  12. #9
    Jul 2016
    Belgium
    I will let you know if it works
    I really apreciate it!
    Thanks alot
  13. #10
    Jul 2016
    Belgium
    I tried to download the file with galletto, but when i gets @ 3% it stops an gives an error. (the voltage is 13.7V)
    Could it be that the software doesn't erase the flash memory? (when i do a read i still have the ori file on it )
    Did some research in the datasheet but couldn't find anything to erase the memory by grounding a pin or something.
    Do i need another programmer to erase memory?
    this is what i have bought already:
    -MPPS
    -GALLETTO
    -k-DCAN
    -ELM327
    -KWP2000Plus
    -Ordered AK-90 programmer
    and a friend of mine has a programmer for the removeable ecu's in the earlier bosch dme's
  14. #11
    Apr 2016
    use K-CAN and download JMGarageFlasher to read/write 512KB in bootmode.
    Best regards.
  15. The Following User Says Thank You to AutoExe3219 For This Useful Post:
    Stijnvdw (19th September, 2016)
  16. #12
    Jul 2016
    Belgium
    Thanks!!!!
    Will let you know when tested on the car
  17. #13
    Jul 2016
    Belgium
    I tried the dme in the car but it doesn't start with the file you gave me AutoExe3219.
    Any idea ?
    Car cranks but no spark.
  18. #14
    Jul 2016
    Belgium
    Found a program named IMMO Universal Decoding 3.2. on remapcar.com
    Is this worth buying?
  19. #15
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Quote Originally Posted by Stijnvdw View Post
    tri it, this is from this program but only immo
  20. The Following 5 Users Say Thank You to Pyromaniak For This Useful Post:
    ecufix (5th October, 2016), giovani (15th February, 2017), semga (27th September, 2017), Stijnvdw (5th October, 2016), wimoko (30th June, 2017)
