Somebody tried programming key using SBB? I have MVP Pro but it seems there are problems with programming key for this car with MVP...
They are a pain. Lexia or PP work well on them, but iv had issues getting transponders in. Last one I couldn't program I had to put a cn3 into the remote key and just code remote. Mvp says access gained / success but it fails
Did you try code blank 7936 or precoded for mitsubishi?
Did not take a pcf7936.
Inside c-crosser 2009 found 7941.
Remotes without battery need to be re-learned again.
There supposed to be manual re-sync procedure
and the procedure is:
- with working remote press unlock button and hold
- press lock button and release
- release unlock button
- car should inform us by open & close doors (not happened to me)
- remotes are erased
(if you have no working remote, londsor can erase it by obd.)
then:
- press & hold: lock and unlock button together at same time for 2 seconds
- release both buttons for 1sec
- press unlock button
- repeat for other remotes
londsor didnt read pin, tried like 15 times ignition on/off but nothing, then cancelled.
