Results 1 to 11 of 11
    Apr 2015
    Default Benz w204 steering column, LIN Bus 1 Malfunction
    hi guys, I took out an ESL out of a Benz W204 to replace a faulty motor now i have a
    problem with a hooter and steeirng wheel buttons not working. i diagnose it with xentry
    and gives me a U100800 LIN Bus 1 has Malfunction error code.
  2. The Following User Says Thank You to sirjay For This Useful Post:
    LannyM (28th February, 2023)
  3. #2
    Dec 2012
    EU
    Double check work you done on the car.
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    Sep 2010
    check plugs from clockspring to airbag, 2 connectors clear and brown, check both
    Apr 2015
    Quote Originally Posted by benzstop View Post
    ive checked the plugs, airbag is fine no fault code from it only the hooter and buttons that dont work and I didnt remove
    the steering when i carried out the job.
    Sep 2010
    Not sure if there is a link bus converter on steering wheel or not, looks sort of like a can connector, converts line to can, if not the steering column module is faulty. What year is your car? Let me know and I will check for you
    Apr 2015
    Its Mercedes Benz W204 2008
    Aug 2013
    What ended up being the problem?
    mastery93's Avatar
    Feb 2018
    Vietnam
    I also have problems like you. how did you handle it
  10. #9
    McDowell's Avatar
    Feb 2019
    Zamunda
    iHey mates, I´ve got the same problem...could you help me please?
  11. The Following User Says Thank You to McDowell For This Useful Post:
    alclot (20th June, 2020)
  12. #10
    Mar 2019
    Earth
    any solution ? i have the same situation with a 2018 GLC
  13. #11
    Mar 2018
    Check steering column pin 4,5,6
    Check steering wheel plug same pin
    4 - power
    5 - ground
    6 - data
    See if any short circuit.
    If have spare steering column and steering wheel, try swap.
  14. The Following User Says Thank You to babeh For This Useful Post:
    fuzz1 (4th April, 2022)
