Results 1 to 13 of 13
    Jan 2016
    Default Zafira B 1.9cdti immo off required
    Could someone remove immo for me. Eeprom 95xxx car zafira B 1.9cdti edc16c39 ECU.
    Jan 2016
    anyone please?
    Meat-Head's Avatar
    More chance of platting fog, most of the car is the immboliser
    fix the fault!
    Jan 2016
    fix the fault!
    car has an electrical fault, in order to find it I need immo off temporarily. Thanks for nothing meathead
    Meat-Head's Avatar
    Eh, err no you dont, bro
    Dec 2012
    EU
    Quote Originally Posted by lobsterosxxx View Post
    Do i understand this right..immo of to find electrical problem?
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
  7. The Following User Says Thank You to gttuning For This Useful Post:
    Meat-Head (25th September, 2016)
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    think he must be trying different ecu ?
    Meat-Head's Avatar
    Quote Originally Posted by smirnoff_rules View Post
    At least he don't review And plugg his own garage on yell.com like some .
    type you home postcode in "companies house " websute
    sminoff rules motors ltd!
  10. #9
    Dec 2012
    EU
    Then swap eep.
  11. The Following User Says Thank You to gttuning For This Useful Post:
  12. #10
    Jan 2016
    Quote Originally Posted by gttuning View Post
    Then swap eep.
    will not help, hard to explain. Car does not start, when you short circuit starter motor car starts and dies when ECU detects speed, immo errors appear now and again, as if it wasn't enough additional immo box installed, starter motor errors and some other problems I will not be explaining not to waste your time (and mine) Complicated situation and I am trying to get my head round it my way so please help or just do not put useless comments. Thank you very much
  13. #11
    Meat-Head's Avatar
    Yeah ok, let you sort it on your own then, but that car will tell you what is wrong
    with it.
    must be a story to the job!
  14. #12
    Dec 2012
    EU
    One time had a zafira with electronic issue caused by wiring in the rear right pass.door.opend all doors and see if your wiring is good where wires comes out from pillars to the door.in my case the wiring got melted and melt wiring loom under driver seat ...over the tunnel ..under pass seat down to rear rec...end up replacing all inside wiring loom.
    Most time its starts melt between door.
  15. The Following 2 Users Say Thank You to gttuning For This Useful Post:
    lobsterosxxx (26th September, 2016), Meat-Head (25th September, 2016)
  16. #13
    Dec 2012
    EU
    Maybe you have same issue.
