Results 1 to 15 of 17
    makura's Avatar
    Default RANGE ROVER P38 IMMO OFF
    Hi guys
    I need help with a range rover P38 showing engine disabled on the desh.
    I have attached dump from the BeCM and ecu.
    Oct 2015
    It is better to read eka code from your becm dump and enter ir with the driver door
  3. The Following User Says Thank You to Tedum For This Useful Post:
    makura (25th September, 2016)
    makura's Avatar
    EKA code which is?
    Did a bit of research and the position were the EKA should be located only has FF FF.
    smokey08's Avatar
    Essex, UK
    You file looks ok but data is missing or corrupt. Where EKA normally is: FFFF. Also where engine ecu sync code: 65535 (FFFF) Last 6 of vin also looks corrupt.
  6. The Following 2 Users Say Thank You to smokey08 For This Useful Post:
    makura (25th September, 2016), Meat-Head (8th October, 2016)
    makura's Avatar
    Quote Originally Posted by smokey08 View Post
    Can it be fixed m8?I would appreciate the help.
  8. #6
    smokey08's Avatar
    Essex, UK
    The fobcode looks intact, We could write in any EKA code. Have you got any tools to reset the immo sync code in the engine ecu? I dont know how to find it in the eeprom.
    What is the last 6 of the VIN ??9130 I assume the remote is not working.
  9. The Following User Says Thank You to smokey08 For This Useful Post:
  10. #7
    makura's Avatar
    No tools to reset ecu m8,all being done by dump would be ideal.
  11. #8
    smokey08's Avatar
    Essex, UK
    Which ecu is it? Gems?
  12. The Following User Says Thank You to smokey08 For This Useful Post:
  13. #9
    makura's Avatar
    Yes its a Gems,3 plugs.
  14. #10
    smokey08's Avatar
    Essex, UK
    I think you should try writing a new EKA code in the becm then try entering it in the doorlock.
    Hopefully someone has previously changed the sync code in the becm to FFFF then perfomed a immo relearn in the engine ecu.
  15. The Following User Says Thank You to smokey08 For This Useful Post:
  16. #11
    makura's Avatar
    is it possible to use a set of dona dumps from another car?
  17. #12
    Oct 2015
    Quote Originally Posted by makura View Post
    Yes you can i will try to post here for you
  18. The Following User Says Thank You to Tedum For This Useful Post:
    makura (26th September, 2016)
  19. #13
    Oct 2015
  20. #14
    makura's Avatar
    Will just the bcm dump work with out a paired ecu dump m8?
    I understand the bcm and ecu are in sync, then how will this dump with different sync code work with my ecu?
  21. #15
    Oct 2015
