Results 1 to 7 of 7
    paganini's Avatar
    Serbia
    Default Peugeot 207 power steering not working
    I have a problem on a peugeot 207 in electric power steering...
    Anyone have a virgin dump or any other solution
    6700 002 166
    q003TA2473ZE 0930
    Eeprom 95160
  2. The Following User Says Thank You to paganini For This Useful Post:
    Lukaszpl (29th September, 2017)
  3. #2
    LT & ES
    Once I've put electronic plate from another psa to original faulty steering, and just needed to adapt steering wheel position sensor( there is a small hole in the Com 2005, where you need to put a small screwdriver when doing alignment).
    Отправлено с моего LG-D620 через Tapatalk
    What fault codes do you have on it?
    juan andres's Avatar
    Quote Originally Posted by paganini View Post
    6700 002 166
    q003TA2473ZE 0930
    Eeprom 95160
    Hi, solution? Thanks frontera help
    Enviado desde mi XT1580 mediante Tapatalk
    Jul 2012
    have same ecu number on 207 electronic power steering with fault C1414 - electronic power steering motor malfunction.
    Anyone have a solution for this?
    Aug 2015
    ¿Alguien tiene alguna solución para el error c1414?
    Ya cambié el micro por uno nuevo y el error continúa.
    Por favor, alguien que tenga la solución, tengo 2 módulos para reparar.
    Quote Originally Posted by starkindustries View Post
    Hola, tengo el mismo problema, diste con la solución? Saludos
    Enviado desde mi moto g(8) power mediante Tapatalk
