Page 13 of 144 FirstFirst ... 3891011121314151617182363113 ... LastLast
Results 181 to 195 of 2154
  1. #181
    Need to delete dpf and egr from ecm on 2008 volvo d13 semi truck, what are the steps and if you can help....thanks!
  2. #182
    May 2013
    Poland, Ostroda, Mazury
    Default VOLVO V70 2.4 170 PS gasolin - DTC OFF (Denso HN2)
    Hello all
    I have a problem with the ECM-9150 in the VOLVO V70 2.4 petrol 170 PS
    ECM-9150 is a mistake used by Volvo and might include the following errors OBD:
    - p0220
    - P0221
    - p0222
    - p0223
    - p0224
    The motor controller is DENSO HN-2.
    The Annex is set read by the IO terminal memory. It is a full flash reading areas as would be read by BDM. Reading the driver did on the table.
    If anyone knows the drivers DENSO enough to remove these errors I'd be very grateful.
    Volvo V70 2.4 170 PS 2001 (Denso HN-2).rar
  3. #183
    Babos's Avatar
    Mar 2012
    Quote Originally Posted by jasiek77 View Post
    Hello all
    - p0220
    - P0221
    - p0222
    - p0223
    - p0224
    Hi here your mod file
  4. #184
    Apr 2016
    friends i need egroff for sportage crd ecu 15c7 error p0403
    0281012099
    1037372105
    thanks!
  5. #185
    Oct 2014
    Worm Hole
    Default your egr off
    In attach egr off.
    Free doesn't exists, Chep doesn't last
  6. The Following User Says Thank You to obd2exe For This Useful Post:
    eculevel (16th January, 2017)
  7. #186
    Default Iveco truck scr-off
    Iveco truck is 251ps data
    Need help with scr off
    Thank you
  8. #187
    Oct 2016
    Please Help me EGR and DPF off KIa C'eed edc17c08kia ceed 1.rar
  9. #188
    Faraday's Avatar
    May 2012
    The dark side of the moon
    need egr off mondeo 2.2 delphi
  10. #189
    Jul 2011
    hi frend. EGR plug disconnected.
    pass.pm
  11. The Following User Says Thank You to draganelektricar For This Useful Post:
    Faraday (18th January, 2017)
  12. #190
    Oct 2016
    Any help for me !!
  13. #191
    Nov 2016
    rieti italy
    Salve, vorrei escludere la seconda sonda lambda questo Mercedes SLK 1,8 file di compressore.
    grazie Attendo tue notizieclk damiano.rar
  14. #192
    korrni's Avatar
    UE
    Hello there, could you help me remove the lambda sensors from a Range Rover Vogue 4.4i ME7.2?
    Ecu is Bosch 0261207715.
    Thank you, dump in attachment, read OBD with Galletto!
  15. #193
    Apr 2014
    Default mazda bongo DPF+ EGR offf
    Hi I need DPF AND EGR OFF on Mazda Bongo ECU RF8P
    Thanks Much.
  16. #194
    Hi friend
    Can you hellp me to remove DPF from Mazda6
    2000 d 147hp
    2007
    Best regards
  17. #195
    Jun 2016
    hi can anyone delete egr on this file. i want to also physically take of the egr with no fault codes
    its a Renault megane 3 1.5 dci 110 hp
